My Haas Bienvenido:
    8. Nederlands
    9. Magyar
    10. Svenska
    11. 中文
    12. Suomi
    13. Norsk
    14. الإنجليزية
    15. български
    16. Hrvatski
    17. Ελληνικά
    18. Slovenský
    19. Slovenščina
    20. 한국어
    21. 日本語
    22. Українська
      • Torno con chuck
      • Frenos de prensa CNC
      • Los paquetes de opciones
      Manejo del soluble y virutas
My Haas Bienvenido:
    8. Nederlands
    9. Magyar
    10. Svenska
    11. 中文
    12. Suomi
    13. Norsk
    14. الإنجليزية
    15. български
    16. Hrvatski
    17. Ελληνικά
    18. Slovenský
    19. Slovenščina
    20. 한국어
    21. 日本語
    22. Українська
DT/DM - Tool Changer Offsets - NGC
Pantalla de inicio de servicio Procedimientos instructivos DT/DM - Tool Changer Offsets - NGC
Recently Updated Last updated: 11/17/2022
- Saltar a la sección - 1. DT/DM - Tool Changer Offset - Next Generation Control (NGC) (5 steps) Back to Top
Power on the machine with your Haas Control Key.
Press [ZERO RETURN].
Press [ALL].
Select Parameters [1].
Select Factory [2].
Make sure Parameters 11.019 (TT_AXIS INVIS AXIS) [3] and 9.019 (V_AXIS INVIS AXIS) [4] are set to FALSE.
Make the T and V Axes visible on the Positions display. Refer to Next Generation Control Position View - Axis Selection.
Press [DIAGNOSTIC].
Select Parameters.
Select Factory.
Type [T] and press [F4] to set the grid offset for the T Axis.
Type [V] and press [F4] to set the grid offset for the V Axis.
Press [RECOVER].
Select Tool Changer Recovery [1] and press [ENTER].
Press [Y] to continue.
Press [M] for Manual Recovery.
Press [ATC FWD] [1] or [ATC REV] [2] until the Home Position [3] is shown.
Record the number of times you press the button to reach the home position. Divide this number by 2. Enter this new value in Parameter 11.078 (TT_AXIS TOOL CHANGE OFFSET).
Place a tool [1] with a flat surface into the tool pocket.
Hold a bubble level [2] under the tool.
Jog the V Axis until the tool is level.
Press [POSITION].
Record the position of the V Axis.
Press [DIAGNOSTIC].
Select Parameters.
Select Factory.
Find Parameter 9.078 (V_AXIS TOOL CHANGE OFFSET) [1]. Enter the recorded value of the V Axis for this parameter.
Press [ALL].
Make sure Parameter 11.019 (TT_AXIS INVIS AXIS) and 9.019 (V_AXIS INVIS AXIS) are set to TRUE.
  • Condiciones
