    8. Nederlands
    9. Magyar
    10. Svenska
    11. 中文
    12. Suomi
    13. Norsk
    14. الإنجليزية
    15. български
    16. Hrvatski
    17. Ελληνικά
    18. Slovenský
    19. Slovenščina
    20. 한국어
    21. 日本語
    22. Українська
      • Les Packs d’options Plus
    8. Nederlands
    9. Magyar
    10. Svenska
    11. 中文
    12. Suomi
    13. Norsk
    14. الإنجليزية
    15. български
    16. Hrvatski
    17. Ελληνικά
    18. Slovenský
    19. Slovenščina
    20. 한국어
    21. 日本語
    22. Українська
DT/DM - Tool Changer Offsets - NGC
Accueil du service Procédures d’aide DT/DM - Tool Changer Offsets - NGC
Recently Updated Last updated: 10/28/2022
- Aller à la section - 1. DT/DM - Tool Changer Offset - Next Generation Control (NGC) (5 étapes) Back to Top
Power on the machine with your Haas Control Key.
Press [ZERO RETURN].
Press [ALL].
Select Parameters [1].
Select Factory [2].
Make sure Parameters 11.019 (TT_AXIS INVIS AXIS) [3] and 9.019 (V_AXIS INVIS AXIS) [4] are set to FALSE.
Make the T and V Axes visible on the Positions display. Refer to Next Generation Control Position View - Axis Selection.
Press [DIAGNOSTIC].
Select Parameters.
Select Factory.
Type [T] and press [F4] to set the grid offset for the T Axis.
Type [V] and press [F4] to set the grid offset for the V Axis.
Press [RECOVER].
Select Tool Changer Recovery [1] and press [ENTER].
Press [Y] to continue.
Press [M] for Manual Recovery.
Press [ATC FWD] [1] or [ATC REV] [2] until the Home Position [3] is shown.
Record the number of times you press the button to reach the home position. Divide this number by 2. Enter this new value in Parameter 11.078 (TT_AXIS TOOL CHANGE OFFSET).
Place a tool [1] with a flat surface into the tool pocket.
Hold a bubble level [2] under the tool.
Jog the V Axis until the tool is level.
Press [POSITION].
Record the position of the V Axis.
Press [DIAGNOSTIC].
Select Parameters.
Select Factory.
Find Parameter 9.078 (V_AXIS TOOL CHANGE OFFSET) [1]. Enter the recorded value of the V Axis for this parameter.
Press [ALL].
Make sure Parameter 11.019 (TT_AXIS INVIS AXIS) and 9.019 (V_AXIS INVIS AXIS) are set to TRUE.
