My Haas Bienvenido:
      • Torno con chuck
      • Frenos de prensa CNC
      • Los paquetes de opciones
      Manejo del soluble y virutas
My Haas Bienvenido:
Axis Servo Motor and Cables - Troubleshooting Guide - NGC - TG0033
Pantalla de inicio de servicio Servomotor y cables del eje - Guía de resolución de problemas - NGC - TG0033
- Saltar a causa - Back to Top
10.4 Servomotor y cables del eje - Guía de solución de problemas
Servomotor y cables de eje - Guía de resolución de problemas - NGC
TG0033
Revision A - 07/2026
Descargue y complete la Lista de verificación del informe de inspección del servomotor que aparece a continuación antes de reemplazar cualquier pieza.
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Síntoma Causa probable Acción correctiva
Alarma 1.9918, 2.9918 o 3.9918 ERROR DE DATOS INTERNOS DEL TRANSDUCTOR SERIE DEL EJE X, Y o Z
Alarma 1.9922, 2.9922 o 3.9922 FALLA DE CANAL DEMOVIMIENTO DEL EJE X, Y o Z DETECTADA
Alarma 1.9923, 2.9923 o 3.9923 ERROR DE TRANSDUCTOR DETECTADO POR EL SOFTWARE EN EL EJE X, Y o Z
Alarma 1.9930, 2.9930 o 3.9930 COMUNICACIÓN DEFICIENTE DEL TRANSDUCTOR SERIE DEL EJE X, Y o Z
Alarma 1.9959, 2.9959 o 3.9959 DESCONEXIÓN DEL TRANSDUCTOR SERIE DEL EJE X, Y o Z
Alarma 1.9948, 2.9948 o 3.9948  FALLA DEL TRANSDUCTOR SERIE SECUNDARIO DEL EJE X, Y o Z
Alarma 1.9949, 2.9949 o 3.9949 ERROR DE TRANSDUCTOR SECUNDARIO DETECTADO POR ELSOFTWARE EN EL EJE X, Y o Z
Alarma 1.9950, 2.9950 o 3.9950   ERROR DE TRANSDUCTOR SECUNDARIO DETECTADO POR ELSOFTWARE EN EL EJE X, Y o Z
Alarma 1.9951, 2.9951 o 3.9951  FALLA DE COMUNICACIÓN DEL TRANSDUCTOR SERIEDEL EJE X, Y o Z
Alarma 1.9960, 2.9960 o 3.9960  FALLA DEL CABLE DEL TRANSDUCTOR SERIESECUNDARIO DEL EJE X, Y o Z
El software de la máquina está desactualizado.
La alarma es obsoleta
Nueva alarma para fallos del codificador actualizada en el software. Actualización a la última versión 100.21.000.1130 o superior;
Se agregaron las alarmas 9719 y 9720 para la detección de fallos del codificador en los ejes primario y secundario de Mocon.
Alarma 1.9719, 2.9719 o 3.9719 FALLA DEL TRANSDUCTOR SERIE PRINCIPAL DEL EJE X, Y o Z
Subcódigo de alarma (0x1) Falla de datos del transductor = (Alarma 9918 ERROR DE DATOS INTERNOS DEL TRANSDUCTOR SERIE)
Las señales del codificador se ven afectadas por el ruido de los cables de alta potencia.
Codificador de servomotor defectuoso.
Consulte la sección Fallos de comunicación de datos en serie/ruido eléctrico a continuación.
Compruebe si hay intrusión de refrigerante en el servo motor. Para las máquinas CMV, se pueden pedir nuevos cables de servo motor para mitigar la intrusión de refrigerante. Consulte HBC-N 03-13-25.
Subcódigo de alarma (0x2) Falla 1 del eje interno del transductor = (Alarma 9922 FALLA DE CANAL DE MOVIMIENTO DETECTADA)
(El canal de movimiento ha informado de una falla interna de un tipo que el control no reconoce)
 Ciclo de alimentación a la máquina. Si el problema persiste, tome el informe de error (Mayús F3) y envíelo por correo electrónico a Haas Service
Subcódigo de alarma (0x3) Falla 2 del eje interno del transductor =  (Alarma 9923 FALLA DE CANAL DE MOVIMIENTO DETECTADA)
 (El software ha informado una falla interna de un tipo que el control no reconoce).
Subcódigo de alarma (0x4) Falla de CRC del transductor = (Alarma 9930 COMUNICACIÓN DEFICIENTE DEL TRANSDUCTOR SERIE)
 (Consulte la sección Fallos de comunicación de datos en serie/Ruido eléctrico a continuación).
Subcódigo de alarma (0x5) Falla del cable del transductor = (Alarma 9959 DESCONEXIÓN DEL TRANSDUCTOR SERIE)
 Los cables no están conectados correctamente o el codificador está defectuoso.  (Inspeccione los cables y conectores. Consulte la sección Cable principal del procesador/transductor a continuación).
Alarma 1.9720, 2.9720 o 3.9720
Subcódigo de alarma (0x1) Falla de datos del transductor = (Alarma 9948 ERROR DE DATOS INTERNOS DEL TRANSDUCTOR SECUNDARIO)
Las señales la escala se ven afectadas por el ruido de los cables de alta tensión.
(Escala lineal defectuosa, problema con el archivo de configuración; tipo de motor incorrecto o tipo de escala incorrecto).
(Compruebe si el transductor de escala está contaminado por refrigerante).
Alarma 1.9720, 2.9720 o 3.9720 FALLA DEL TRANSDUCTOR SERIE PRINCIPAL DEL EJE X, Y o Z
Subcódigo de alarma (0x2) Falla 1 del eje interno del transductor = (Alarma 9949 FALLA DEL TRANSDUCTOR SECUNDARIO DETECTADA POR SOFTWARE)
(El canal de movimiento ha informado de una falla interna de un tipo que el control no reconoce)  Ciclo de alimentación a la máquina. Si el problema persiste, tome el informe de error (Mayús F3) y envíelo por correo electrónico a Haas Service
Subcódigo de alarma (0x3) Falla 2 del eje interno del transductor =   (Alarma 9950 FALLA DEL TRANSDUCTOR SECUNDARIO DETECTADA POR SOFTWARE)
Subcódigo de alarma (0x4) Falla de CRC del transductor =   (Alarma 9951 FALLA DE COMUNICACIÓN EN SERIE DEL TRANSDUCTOR SECUNDARIO )
(Las señales de la escala lineal se ven afectadas por el ruido de los cables de alta potencia). (Consulte la sección Fallos de comunicación de datos en serie/Ruido eléctrico a continuación).
Subcódigo de alarma (0x5) Falla del cable del transductor =  (Alarma 9960 FALLA DEL CABLE DEL TRANSDUCTOR SERIE )
(Los cables no están conectados correctamente o la escala lineal está averiada). (Inspeccione los cables y conectores. Consulte la sección Cable principal del procesador/transductor a continuación).
Alarmas 1.161, 2.161, 3.161 FALLO DEL ACCIONAMIENTO DEL EJE X, Y o Z
Servoamplificador defectuoso. Compruebe el conjunto del amplificador correspondiente.
Consulte Servo Amplifier - Guía de solución de problemas para solucionar problemas del amplificador.
Alarma 1.217, 2.217, 3.217 ERROR DE FASE DEL EJE X, Y o Z Los cables no están conectados correctamente  Inspeccione los cables y conectores. Consulte la sección Cable del procesador/codificador principal a continuación.
Se ha instalado el tipo de motor incorrecto. Compruebe que se ha instalado el tipo de motor correcto.  (Sigma-5 o Sigma-7)
Alarma 1.645, 2.645, 3.645 FALLO DE TIERRA DEL AMPLIFICADOR DEL EJE X, Y o Z Cable de alimentación defectuoso. Inspeccione los cables y conectores. Consulte la sección  Cable de alimentación a continuación.
Servomotor defectuoso. Compruebe el servomotor correspondiente. Consulte la sección  Servo motor a continuación.
Alarma 1.993, 2.993, 3.993 CORTOCIRCUITO DEL EJE X, Y o Z Cable de alimentación defectuoso. Inspeccione los cables y conectores. Consulte la sección  Cable de alimentación a continuación.
Alarma 1.103, 2.103, 3.103 ERROR DE SERVO DEL EJE X, Y o Z DEMASIADO GRANDE
Alarma 1.9920, 2.9920, 3.9920 ERROR DE POSICIÓN X, Y o Z DEMASIADO GRANDE
Las señales del codificador se ven afectadas por el ruido de los cables de alta potencia. O codificador defectuoso. Consulte Fallas de comunicación de datos serie / ruido eléctrico sección a continuación. Compruebe los pasos del codificador/revolución frente al paso del tornillo de bola y compruebe que los recuentos del codificador son exactos por cada rotación.
El freno del motor del eje, no se desengancha cuando los servos están activados. Consulte la sección  Freno del motor  a continuación:
El husillo de bolas del eje está dañado. Compruebe el husillo de bolas del eje correspondiente.
Consulte Husillo de bolas - Guía de solución de problemas para solucionar problemas del husillo de bolas.
Acoplamiento del tornillo de bolas desalineado debido a un choque
Verifique que el acoplamiento del motor del tornillo de bolas esté alineado; consulte Tornillo de bolas - Guía de resolución de problemas para obtener más información sobre cómo volver a alinear el acoplador
NOTA: Verifique que el cable de alimentación no esté defectuoso antes de intentar alinear el acoplamiento del motor.
Alarma 103 ERROR DE SERVO DE EJE DEMASIADO GRANDE, durante el proceso de retorno a cero. El eje cero vuelve en la dirección incorrecta. El sensor doméstico se está haciendo durante el proceso de retorno cero haciendo que el eje regrese a cero en la dirección opuesta. Compruebe el interruptor de inicio del eje para asegurarse de que no hay virutas de metal en la parte superior del sensor.
Alarma 552 DISYUNTOR ACTIVADO (en UMC-1000) Conducto de cables y cables dentro del conducto dañados. Retire el panel trasero. Inspeccione el conducto de cables. Si está dañado, póngase en contacto con el Departamento de Servicio de Haas para obtener asistencia.
Los servos de la máquina hacen un zumbido mientras están en reposo, avance lento o rápido. Es necesario ajustar el corrector de la rejilla del eje. Realice el procedimiento de ajuste de corrector de cuadrícula del eje.
El husillo de bolas no está alineado. Verifique que el husillo de bolas no se atasque durante el desplazamiento y que esté correctamente alineado.
Parámetros desactualizados. Descargue los archivos de configuración más recientes. Si el servo del eje continúa zumbando, póngase en contacto con su HFO local para obtener más información sobre la resolución de problemas.
Alarma 9804 FALLA DE CONEXIÓN A TIERRA DE 240 V CA se genera cuando regreso a cero un eje.
Hay un cortocircuito en el cable o motor. Compruebe si hay un cortocircuito en el servomotor y el cable correspondientes. Vea los videos de Inspección del motor y cable de alimentación del servomotor.
{icon:fa fa-file-text} Nota: Si se genera una alarma en una máquina ST cuando el eje A es cero, regrese el cable del eje LT y verifique que no haya cortocircuito en el motor.
Alarma 9804 FALLO DE TIERRA DE 240 VCA
Y/O
Alarma 993 CORTOCIRCUITO
Y/O
Puede haber intrusión de refrigerante en el servo motor del eje.
Inspeccione el motor en busca de intrusión de refrigerante.  Para las máquinas CMV, se pueden pedir nuevos cables de servo motor para mitigar la intrusión de refrigerante. Consulte HBC-N 03-13-25.
Si el motor se reemplaza debido a una intrusión de refrigerante, asegúrese de pedir la cubierta de montaje del servomotor del eje para montajes de motor que sea compatible con el motor.
Consulte el documento VF/VR - Cubierta de montaje del motor X/Y - Documento de referencia para verificar los montajes del motor y sus cubiertas. Este documento también tendrá los números de pieza para realizar pedidos.
Cualquiera de las siguientes alarmas se genera después de reemplazar el servo motor Mitsubishi por un servo motor Yasakawa en el eje al que se reemplazó su sensor de movimiento.
1.9959  FALLO DEL CABLE DEL CODIFICADOR SERIE DEL EJE X
2.9959  FALLO DEL CABLE DEL CODIFICADOR SERIE DEL EJE Y
3.9959  FALLO DEL CABLE DEL CODIFICADOR SERIE DEL EJE Z
No se cargaron parches para añadir parámetros y ajustes para el motor Yaskawa.  Cargue configuraciones para aplicar los parches. Archivo de configuración - Descargar/Cargar - NGC.
Cualquiera de las siguientes alarmas se genera después de reemplazar el servo motor Mitsubishi con un servo motor Yasakawa en ejes que no tuvieron su servo motor reemplazado y aún tienen un servo Mitsubishi.
1.9719  FALLO DEL CABLE DEL CODIFICADOR SERIE DEL EJE X
2.9719  FALLO DEL CABLE DEL CODIFICADOR SERIE DEL EJE Y
3.9719 FALLO DEL CABLE DEL CODIFICADOR SERIE DEL EJE Z
Subcódigo 0x4 o 0x5.
Los parches de conversión de Mitsubishi extra a Yaskawa no se reemplazaron.
Elimine los parches innecesarios. Revise el CMV AD0656 - X/Y - servo motor del eje - Reemplazo o el CMV AD0556 - Eje Z - servo motor - Reemplazo. Para obtener información adicional sobre la sustitución de servomotores de eje lineal, consulte RD0100 Cómo eliminar un archivo de parche para obtener información adicional sobre la eliminación de archivos de parche.
Serial Data Communication Faults / Electrical Noise
Los servomotores Sigma-5, los codificadores sin contacto, emiten señal de datos serie al control. Si falta la señal de datos serie o se vuelve poco fiable, el control generará un error de comunicación de datos serie. El ruido eléctrico puede hacer que la señal de datos serie del codificador se vuelva poco fiable y cause falsas alarmas. Siga la guía de solución de problemas a continuación para ayudar a eliminar el ruido en el sistema.
  1. Conexión a tierra incorrecta de la máquina. Asegúrese de que el tamaño del cable de tierra es correcto. También el cable de tierra debe funcionar hasta el panel eléctrico.
  2. Ruido de otros equipos. Asegúrese de que la máquina no comparta su servicio eléctrico con otra máquina.
  3. Conectores de datos del codificador sueltos en pcb o en el codificador del motor, puede hacer que los datos serie se vuelvan poco fiables. Consulte la sección  Cable del procesador/codificador principal
  4. .
  5. Conectores de alimentación de tierra o de alta tensión sueltos inducirá ruido en el sistema.
    • armario eléctrico comprobar si hay conexión suelta en todos los terminales de alimentación de tierra y de alta tensión (unidad vectorial, contactores wye-delta, transformador.. etc.).
    • Colgante compruebe si hay conectores de terminales sueltos.
    • cabezal de husillo compruebe si hay terminales de potencia de motor y tierra sueltos.
  6. el filtros de ferrita suprimir el ruido de alta frecuencia producido por los amplificadores y la unidad vectorial, cuando los servos están encendidos. Asegúrese de que están instalados en:
    • Cables de datos del codificador. Asegúrese de que haya un filtro de ferrita P/N 64 1252 instalado en todos los cables de datos del codificador.
    • Cables de alimentación del motor axis. Asegúrese de que haya un filtro de ferrita P/N 64-1252 instalado en los cables de alimentación del motor del eje X, Y, Z [1].
    • Cables del motor del husillo. Asegúrese de que haya un filtro de ferrita instalado en la salida del motor de la unidad vectorial.
      Fora 40HP vector con 6 cables [1] utilizar ferrita P/N 64-1254.
      Fora 40HP vector con 3 cables [2] utilizar ferrita P/N 64-1252.
      Fora 20HP vector con 6 o 3 cables [3, 4] utilizar ferrita P/N 64-1252.
  7. Enrutamiento de cables. Asegúrese de que el cable del codificador esté separado de los cables de husillo/eje/bomba de alta potencia.
Maincon PCB / Encoder Cable
Acción Correctiva:
Examine el conector [1] en la Maincon. Asegúrese de que no esté dañado.
Examine el cable. Busque signos de daño o rigidez. El conector [4] tiene dos carcasas [2,3] para los pines de cable.
Si los pasadores han sido empujados en el motor, debe reemplazar el motor y el cable juntos.
Asegúrese de que el cable esté firmemente conectado en ambos extremos. Vuelva a sentar ambas conexiones. Asegúrese de que el cable esté instalado en el conector correcto en la PCB Maincon o MOCON.
Power Cable
Inspeccione el conector en el motor, busque conexiones sueltas entre el motor y el cable o entre los terminales de pala de cable y el amplificador. Compruebe si hay contaminación del conector.
NOTA: Tire suavemente de los cables al comprobar si hay una conexión suelta en el lado del amplificador. Si tira de los cables con fuerza excesiva puede dañarlos.
Busque signos de daño o rigidez en el cable y el conector. Desconecte el cable de alimentación del amplificador y del motor. Mida la resistencia de rama a rama (cables rojos, blancos y negros) y de la rama a tierra (cable verde/amarillo). Asegúrese de que las mediciones dan como resultado una conexión abierta. Consulte la tabla siguiente como referencia.
NOTA: Si la máquina está experimentando alarmas intermitentes de cortocircuito, mueva el eje a la ubicación donde el cable estaría más doblado antes de realizar esta prueba. Esto puede mejorar la probabilidad de encontrar un cortocircuito intermitente.
Tabla de referencia del cableado del cable de alimentación del servomotor
Función Color  Extremo del motor Extremo del amplificador
Fase A Rojo A Pala
Fase B Blanco B Pala
Fase C Negro C Pala
Tierra del chasis Verde/amarillo D Anillo
Trenza Trenza No conectado
Realice una prueba de continuidad entre el cable de tierra y el blindaje trenzado. Si la prueba de continuidad falla, el blindaje del cable está afectado.
Compruebe la continuidad de cada pata de un extremo del cable a la pata correspondiente en el otro extremo del cable. Consulte la tabla anterior para ver la referencia de cableado. Si hay una conexión abierta, hay un problema con el cable.
Utilice la siguiente tabla de resolución de problemas para determinar si el motor, el amplificador o los cables están defectuosos.
Cuando se produzca la alarma 993 CORTOCIRCUITO, desconecte el cable de alimentación del eje del motor. Presione [RESET] y avance el eje.
Si se produce la Alarma 103 ERROR DE SERVOMOTOR DEL EJE DEMASIADO GRANDE, el motor está defectuoso. Si se produce otra alarma 993 CORTOCIRCUITO, el cable o amplificador están defectuosos.
Para determinar si el cable o el amplificador están defectuosos, desconecte el cable de alimentación del eje del motor y del amplificador. Presione [RESET] y avance el eje.
Si se genera la alarma 993 CORTOCIRCUITO, el amplificador está defectuoso. Si se genera la alarma 103 ERROR DE SERVOMOTOR DEL EJE DEMASIADO GRANDE, el cable está defectuoso.
Servo Motor
Acción Correctiva:
Desconecte e inspeccione el conector del cable de alimentación en el lado del motor. Verifique que los conectores del motor no estén contaminados; la contaminación por refrigerante puede generar alarmas de falla de accionamiento y dañar el amplificador. Compruebe que el cable también esté conectado al amplificador correspondiente.
Mida la resistencia entre los pines etiquetados A, B y C del conector del motor a la tierra del chasis.
  • La lectura debe mostrar un circuito abierto.
  • Si la lectura no muestra un circuito abierto, el motor tiene una falla
Realice una prueba de continuidad entre el pin de tierra y la tierra del chasis. El multímetro debe sonar o indicar menos de 1 ohmio de resistencia para la continuidad; de lo contrario, hay un cortocircuito en el motor. Mida la resistencia entre los pines etiquetados A, B y C; consultela tabla a continuación para conocer los valores de resistencia.
NOTA: Se ha añadido resistencia nominal del devanado a la tabla para el método de prueba de 4 cables; cuando use un multímetro, utilice la columna de valor de resistencia típica para los valores esperados.
Cono 30 DC-1 - Motor del carrusel de herramientas sin freno
Importante: Las máquinas fabricadas antes del 3/1/2025 tendrán el motor sin freno.
El motor del carrusel de herramientas DC-1 es un motor sigma7 tamaño 04. La disposición de pines para las fases tiene un aspecto diferente al de otros motores de eje.
Esta imagen muestra los pines del conector del motor:
  1. Gnd
  2. Fase A
  3. Fase B
  4. Fase C
NOTA: El pasador de esmeril [1] debe ser más largo que los otros pasadores como se muestra en la imagen.
1.0"
Tipo de motor
NP Haas
MPN
Tamaño del motor
Resistencia nominal del devanado (ohmios)
Resistencia típica del bobinado medida por el multímetro digital (ohmios)
Sigma 5
62-10011/ 62-10010
SGMGV-09ADA-HA11/ SGMGV-09ADA-HA21
0.894
0.9
62-10013/ 62-10012
SGMGV-13ADA-HA11/ SGMGV-13ADA-HA21
13
0.554
0.6
62-10015/ 62-10014
SGMGV-20ADA-HA11/ SGMGV-20ADA-HA21
20
0.291
0.4
62-0101/ 62-10027
SGMSV-30ADV-YA11/ SGMSV-30ADA2E
30
0.179
0.3
Sigma 7
62-0127B
SGM7A-02AFK-HA21
6.6
62-4445 SGM7A-04A7D61 4 4.3 4.2
62-0117/ 62-0124
SGM7G-09AFA-HA11/ SGM7G-09AFA-HA21 9 0.882
62-0119/ 62-0118
SGM7G-13AFA-HA11/ SGM7G-13AFA-HA21
13
0.557
0.6
62-0120/ 62-0123
SGM7G-20AFA-HA11/ SGM7G-20AFA-HA21
20
0.286
0.4
62-0122/ 62-0121
SGM7G-30AFB-HA11/ SGM7G-30AFB-HA21
30
0.177
0.2
Mitsubishi J5
62-0138/ 62-0141
HK-ST102WK-S101212/ HK-ST102WBK-S101212
1.254
1.4
62-0137/ 62-0140
HK-ST172WK-S101212/ HK-ST172WBK-S101212
13
0.807
0.9
62-0142/ 62-0139
HK-ST202AWK-S101212/ HK-ST202AWBK-S101212
20
0.558
0.7
Mitsubishi J3
62-0087/ 62-0088
HF-SP81MK-S12/ HF-SP81MBK-S12
1.149
1.4
62-0089/ 62-0095
HF-SP131MK-S12/ HF-SP131MBK-S12
13
0.692
0.8
62-0096/ 62-0097
HF-SP181MK-S12/ HF-SP181MBK-S12
20
0.456
0.5
Delta
62-0108/ 62-0109
ECMC-FW1308RS/ ECMC-FW1308SS
0.737
 0.8
Motor Brake
Acción Correctiva:
Vuelva a asentar la conexión de los conectores P3, P4 o P5 en la PCB de E/S.
Mida la tensión a través de los cables rojos y negros.
Presione[POWER OFF]. No debe haber tensión.
Pulse [RESET] para eliminar las alarmas. La tensión debe estar entre 20-30 VCC.
Examine la conexión en el freno del motor [2] y los conectores de alimentación [3] en busca de contaminación. Vuelva a sentar las conexiones.
Si no hay tensión presente, consulte:
  • Control de próxima generación - PCB de E/S -Guía de solución de problemas
Electrical Diagrams
  • Condiciones
