      • Les Packs d’options Plus
Servo Amplifier - Replacement - AD0280
Accueil du service Procédures d’aide Servo-amplificateur - Remplacement - AD0280
12.1 Servo-amplificateur - Remplacement
Recently Updated Last updated: 08/22/2023
AD0280
Révision B - 03/2026
Cette procédure vous indique comment retirer un servo-amplificateur et installer un servo-amplificateur intelligent.
Si vous remplacez un servo-amplificateur qui a été fabriqué avant 2007, référez-vous à la Charge auxiliaire PCB (AUX) - Remplacement.
Le document s’applique à ces pièces
  • 93-32-5549      AMP, 90A BL SMART
  • 93-32-5550J       AMP, 30A BL SMART
  • 93-32-5550N  AMP, 30A BL SMART
  • 93-32-3551J      AMP, 45A BL SMART
  • 93-32-3551N    AMP, 45A BL SMART
  • 93-32-5552G    AMP, 60A BL SMART
  • 93-4988       AMP, 60A BL SMART
  • 93-4989       AMP, 90A BL SMART
  • 93-5088      AMP, 30A DIGITAL AMP
  • 93-5089       AMP, 45A DIGITAL AMP
REMARQUE : Les amplificateurs numériques sont entièrement rétrocompatibles avec les amplificateurs intelligents BL.
REMARQUE : Consultez Servo-amplificateur - Guide d’identification pour en savoir plus.
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Replacement
Appuyez sur [POWER OFF].
Réglez le disjoncteur principal sur la [OFF]position.
Verrouillez le disjoncteur principal. Utilisez un verrou approuvé avec une étiquette de sécurité approuvée.
Danger : Si la lumière de l'indicateur de tension est allumée, ne touchez pas les composants électriques. La haute tension dans l'armoire électrique peut vous tuer. Attendez que l'indicateur de tension LED s'évade complètement.
Déconnectez les câbles du servo-amplificateur utilisé. Retirez le servo-amplificateur utilisé.
Installez le servo-amplificateur intelligent de remplacement [1].
Connectez le câble de commande actuel [2].
Connectez les câbles servo [3]. Les câbles sont codés en couleur.
Connectez les sauteurs à haute tension [4] aux terminaux de l'amplificateur de servo adjacent.
