Servo Amplifier - PCB Auxiliary (AUX) Load - Replacement - AD0263
Service Home How To Procedures Servo Amplifier - PCB Auxiliary (AUX) Load - Replacement - AD0263
Recently Updated Last updated: 02/01/2022
AD0263
Applies to machines built from: January, 1996
- Jump to Section - 1. Introduction 2. Electrical Safety 3. Installation (1 step) Back to Top
  1. Servo Amplifier
  2. Smart Servo Amplifier
  3. Smart Servo Amplifier with AUX Load
Do this procedure to install the AUX load [3] when you install a Smart Servo Amplifier [2]. The replacement amplifier must have the same amp rating as the servo amplifier [1] that you remove. You must install the AUX load [3] on the replacement Smart Servo Amplifier [2] if you have these two conditions:
  • The machine has only two servo amplifiers [1].
  • You must replace only one of the servo amplifiers [1] with a Smart Servo Amplifier [2].
Note: In other words, if after the installation the machine has only one servo amplifier [1], the replacement Smart Servo Amplifier must have the AUX load [3].
  • 93-32-4995    PCB, AUXILIARY LOAD SMART AMP
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Remove the (2) screws [2] from the replacement Smart Servo Amplifier [1]. Use the (2) screws [2] to install the PCB, AUXILARY LOAD SMART AMP [A] onto the replacement Smart Servo Amplifier [3].
Connect the 570 cable to the connector on the PCB, AUXILARY LOAD SMART AMP [A].
