Haas Cobot Package 10 kg
Haas 10 kg Cobot Package
Starting Price: US$44,995 CNY ONLY
10 kg Capacity Cobot System
All-in-one cobot kit for your new machine! The Haas 10 kg Cobot Package includes everything required to run your new cobot directly from the Haas control. This kit features the HC10 Cobot with a 10 kg part capacity, dual pneumatic grippers, protective barriers, a temporary mounting base*, a parts table, a part flip station, and all necessary hardware and cables.
10 KG CAPACITY | 1000 MM REACH
AVAILABLE ON: Small VFs, ST-10 through ST-28, UMC-500/SS, and UMC-750/SS
*Does not ship pre-built. The temporary mounting base is for optional use, and is not included in Europe. Floor mounting is recommended. Cobot carries a one-year warranty.
Compare Machines
HC10 Machine Ready Cobot Kit
The Haas Cobot Package-10kg is a fully integrated, plug-and-play, 10 kg capacity collaborative robot for Haas machines. The system is controlled entirely by the Haas control when connected to the machine’s electrical interface box. Includes: 6-axis cobot, software interface for direct control through the Haas machine, teach pendant and cobot controller, safety light curtain, and all necessary electrical hardware to interface directly with the Haas control.
AVAILABLE ON:
Vertical Mills: VF-1, VF-2/YT/SS/SSYT, VM-2, DC-1, MM, SMM, DT-1, DT-2, DM-1, DM-2
5-Axis Machines: UMC-500/SS, UMC-750/SS
Lathes: ST-10/Y, ST-15/Y, ST-20/Y, ST-25/Y, ST-28/Y
Includes:
✓ HC10 Cobot
✓ 2 Meter Light Curtain
✓ Single Pneumatic Gripper
✓ Adjustable Stand: 24"-36" (610-914 mm)
✓ Parts Table
✓ Parts Template, 0.75" - 4" (19 - 101 mm)
✓ Part Flip Station
✓ Permanent Anchoring Hardware
NOTE: Temporary mounting base not included in Europe
BUILD & PRICE
Contact Distributor
  • Build-&-Price
  • Machine Info
  • Specs
GET YOUR INSTANT QUOTE NOW.
Please enter your information below to receive your instant quote. To skip this step in the future, simply enter a password below to create your free MyHaas account.
Already have an account? Sign In
< Return
Contact Information
+ Add Address
Enter a password to create a MyHaas account! (optional)
Want to share your quote? (optional)
+ Another
SERIES INFO
SET UP
COMPATIBLE HAAS MACHINES
FIELD INSTALL
RELATED PRODUCTS
SAFETY ACKNOWLEDGMENT FORM
Sign and return the Safety Acknowledgment form to your local HFO to get a head start on your purchase!
Sign The Form
  • Layout Drawing
  • Cobot 10 Installation
  • ANCHORING INSTALLATION
  • Cobot Maintenance
  • Safety Acknowledgement Form
  • Gripper Installation
  • Assembly Drawing
  • Light Curtain Mounting Instructions
  • Stencil: Light Curtain Mounting Pattern
  • Stencil: Cobot Mounting Bolt Pattern
SET UP
HAAS COBOTS: STEP-BY-STEP SET UP
Alex walks us step-by-step through setting up and programming a Haas Cobot to load and unload a part for unattended operation.
PROGRAMMING AND SET UP ARE EASY
FULLY INTEGRATED WITH THE HAAS CONTROL!
1. SET UP RAW MATERIAL
2. SET MATERIAL PICKUP
3. SELECT WORKHOLDING
4. SET LOAD POSITION
5. SET PART DROP OFF
6. RUN THE PARTS!
Connection Overview
Haas Machine + Haas Cobot = Quick Set Up and Easy Automation
Haas has simplified the communication between the CNC machine and the cobot with our exclusive Electrical Interface Box. This box includes every connection needed to be fully set up for robotic automation, including outlets for cobot power, cobot communication, safety device interlock, remote jog handles, and remote E-stops. Additional Electrical Interface Boxes can be purchased separately, allowing you to easily move your cobot between multiple machines.
Haas Robot/Cobot Interface
Easy-to-Use Robot/Cobot Interface
The cobot is set up directly through the Haas control using the Haas Robot Interface, which guides the operator through the steps necessary to quickly program the cobot’s motions using the Haas Touch Remote Jog Handle. Answering simple questions, the operator enters basic information by either positioning the part grippers and pushing a single button to record the position, or by entering basic numerical values. The motions are recorded and values are calculated automatically by the control, and the cobot is ready for automatic parts loading.
A basic part management table can be created by setting up a grid pattern template of equally spaced rows and columns. The cobot grippers can be configured for various part shapes – such as round, hex, and square bars – and adjusted or modified to best fit your parts.
The cobot operates in the background during normal machining operations, returning parts to the storage table and retrieving new raw pieces, while parts are being machined. The result is near-continuous unattended machining.
Our easy-to-use Haas Robot Interface uses simple, step-by-step instructions to help the operator “teach” a 6-axis cobot the correct positions for picking up, loading, and unloading parts.
  • The cobot’s motion is operated directly from the Haas Touch Remote Jog Handle,  allowing for seamless integration
  • Step-by-step instructions and graphics help guide the operator through the setup process, for example:
    • Set the part template pattern – number of rows and columns
    • Set the first part pick-up position
    • Teach the linear path the robot arm will follow to the ready position
    • Set the ready position – where the cobot will wait until machining is complete
    • Set the load and unload positions at the workholding
    • Set the drop-off position for the first completed part
The APL sequence has been expanded to allow for additional capabilities for the cobot that our other standard APLs can't do.  Expanded capabilities for the cobot include:
  • Part Flipping
  • Pickup and dropoff from multiple locations (allowing for conveyor feeds, etc.)
  • Load and unload from multiple locations (main or sub spindle, multiple vises)
APL Mode For Robot/Cobot Program Operation
Simple to Operate in APL Mode
APL Mode seamlessly combines the part program selected in Memory [MEM] with a designated robot/cobot setup template to automate part production and boost productivity.
A new M-code was developed for use with Auto Part Loaders (APLs) and robots/cobots. M299 is typically used at the end of a part program. When the program is started by pressing [CYCLE START] in Memory mode, the M299 acts exactly like an M30 (Program End and Reset). But if the program is started while “APL Mode” is active, then the M299 will command the cobot to load the first part from the table, and then run the active program in Memory.
  • APL Mode
    • Simply replace your M30 with an M299 at the end of your part program
    • From the Run Job tab, press [INSERT] to select the designated APL setup template (Job) and turn on APL Mode; an “APL Mode” watermark will appear over your program, and you’re ready to go
    • Press Cycle Start, and the robot will load the first part, and execute the part program in Memory
    • While the part is being machined, the robot will drop off the completed part, and then pick up new raw stock and stage it at the designated load position
    • The operator can monitor table status, the number of parts completed, which number part is inside the machine, and which part is next all from Run Job page
    • The cycle continues until all parts on the table are completed, or a specified number of parts is reached
Cobots Must Be Installed by Your Local HFO. Cost Will Vary Based on Application.
The Haas Cobot requires assembly and set up. Each application is unique. Your local Haas Factory Outlet will provide integration, installation, and training, with pricing based on your application.
  • Cobot VMC Installation
  • Cobot Lathe Installation
  • Cobot DT/DM Installation
  • Cobot UMC Installation
Field-Install Requirements
HC10 Machine Requirements
VMC Requirements
  • 100.24.000.1001 software version or higher
  • VF-1/2 & VM-2 Built By Date:  (see machine requirements in either procedure)
    • Haas AUTODOOR
    • Haas AUTO WINDOW
  • 34-349xB I/O board or later
  • 93-1000297 I/O DOOR ASSY HINGED I/O PCB HINGE DOOR
  • 93-1000610 REMOTE JOG HANDLE TOUCH LCD (RJH-XL) REMOTE JOG HANDLE - XL
Lathe Requirements
  • 100.24.000.1001 version or higher
  • ST-10/15/20/25/28 Reboot Sheet Metal (Flat Face)
  • Haas AUTODOOR
UMC Requirements
  • UMC-500/SS Built By Date: 3/18/2022 with 90 Degree Control Cabinet & Haas Workholding Ready
  • Haas AUTODOOR or AUTO WINDOW
DT/DM Requirements
  • DT/DM/MM/SMM/DC-1/UMC-350 Built By Date:  (see machine requirements in either procedure)
    • Haas AUTODOOR
    • Haas AUTO WINDOW
Contact Your HFO For More Information
Cobot Package-10kg – Compatible Machines
Product Image
VF-1
CNC Vertical Mill with 20" x 16" x 20" travels
Starting at US$62,995 CNY ONLY
Learn More Build & Price
Haas VF-2
VF-2
CNC Vertical Mill with 30" x 16" x 20" travels
Starting at US$66,995 CNY ONLY
Haas VF-2SS
VF-2SS
Super-Speed CNC Vertical Mill with 30" x 16" x 20" travels
Starting at US$79,995 CNY ONLY
Haas VF-2SSYT
VF-2SSYT
Super-Speed CNC Vertical Mill with 30" x 20" x 20" travels
Starting at US$89,995 CNY ONLY
Haas VF-2YT
VF-2YT
Starting at US$74,995 CNY ONLY
Haas VM-2
VM-2
CNC Vertical Mold Machine with 30" x 20" x 20" travels
Starting at US$106,995 CNY ONLY
Haas DM-1
DM-1
CNC Drill/Mill Center with 20" x 16" x 15.5" travels
Starting at US$73,995 CNY ONLY
Haas DM-2
DM-2
CNC Drill/Mill Center with 28" x 16" x 15.5" travels
Starting at US$76,995 CNY ONLY
Haas DT-1
DT-1
CNC Drill/Tap Center with 20" x 16" x 15.5" travels
Starting at US$64,995 CNY ONLY
Haas DT-2
DT-2
CNC Drill/Tap Center with 28" x 16" x 15.5" travels
Haas UMC-500
UMC-500
5-Axis CNC Vertical Machining Center with 24" x 16" x 16" travels
Starting at US$148,995 CNY ONLY
Haas UMC-500
UMC-500SS
Super-Speed 5-Axis CNC Vertical Machining Center with 24" x 16" x 16" travels
Starting at US$176,995 CNY ONLY
Haas UMC-750
UMC-750
5-Axis CNC Vertical Mill with 30" x 20" x 20" travels
Starting at US$182,995 CNY ONLY
Haas UMC-750SS
UMC-750SS
Super-Speed 5-Axis CNC Vertical Mill with 30" x 20" x 20" travels
Starting at US$227,995 CNY ONLY
Haas DC-1
DC-1 Drill Center
High-Speed Drill Center with 23.6" x 17.7" x 13" travels, 30 taper
Starting at US$65,995 CNY ONLY
US$50,995
Haas ST-10
ST-10
CNC Lathe with 12" x 16" max capacity and 1.75" bar capacity
Starting at US$60,995 CNY ONLY
Haas ST-10Y
ST-10Y
Y-Axis CNC Lathe with 11" x 16" max capacity and 1.75" bar capacity
Starting at US$97,995 CNY ONLY
Product Image
ST-15
CNC Lathe with 12" x 16" max capacity and 2.5" bar capacity
Haas ST-15Y
ST-15Y
Y-Axis CNC Lathe with 11" x 16" max capacity and 2.5" bar capacity
Starting at US$102,995 CNY ONLY
Haas ST-20
ST-20
CNC Lathe with 13" x 22.5" max capacity and 2.5" bar capacity
Haas ST-20Y
ST-20Y
Y-Axis CNC Lathe with 11.75" x 22.5" max capacity and 2.5" bar capacity
Starting at US$108,995 CNY ONLY
Haas ST-25
ST-25
CNC Lathe with 13" x 22.5" max capacity and 3.0" bar capacity
Haas ST-25Y
ST-25Y
Y-Axis CNC Lathe with 11.75" x 22.5" max capacity and 3.0" bar capacity
Starting at US$120,995 CNY ONLY
Haas ST-28
ST-28
CNC Lathe with 13" x 22.5" max capacity, A2-8 nose, and 4.0" bar capacity
Starting at US$83,995 CNY ONLY
Haas ST-28Y
ST-28Y
Y-Axis CNC Lathe with 11.75" x 22.5" max capacity, A2-8, and 4.0" bar capacity
Starting at US$127,995 CNY ONLY
RELATED PRODUCTS
Product Image
Haas Cobot Package 5 kg
5 kg Capacity Cobot System
Starting at US$29,995 CNY ONLY
Product Image
Haas Cobot Package 15 kg
15 kg Capacity Cobot System
Starting at US$59,995 CNY ONLY
Axes S.A.E METRIC
Controlled Axes 6 6
Capacities S.A.E METRIC
Max Load Capacity at Wrist 22.0 lb 10 kg
Reach 39.0 in 1000 mm
Repeatability 0.0012 in 0.030 mm
Single Gripper S.A.E METRIC
Max Part Weight 14.5 lb 6.6 kg
Gripper Assembly Weight 7.5 lb 3.4 kg
Part Size - Round ø 0.63 in to 6.20 in 16 mm to 157 mm
Part Width - Rectangular 0.38 in to 6.00 in 10 mm to 152 mm
Part Length - Rectangular 0.90 in to 2.20 in 23 mm to 56 mm
Dual Gripper S.A.E METRIC
Max Part Weight (per gripper) 2.5 lb 1.1 kg
Gripper Assembly Weight 7.0 lb 3.2 kg
Part Size - Round ø 1.00 in to 6.00 in 25 mm to 52 mm
Part Width - Rectangular 0.75 in to 6.25 in 19 mm to 159 mm
Part Length - Rectangular 0.90 in to 1.65 in 23 mm to 42 mm
Motion S.A.E METRIC
Motion Range – J1 720 ° 720 °
Motion Range - J2 270 ° 270 °
Motion Range - J3 306 ° 306 °
Motion Range - J4 720 ° 720 °
Motion Range - J5 360 ° 360 °
Motion Range - J6 720 ° 720 °
Speeds S.A.E METRIC
Max Speed - J1 100 °/sec 100 °/sec
Max Speed - J2 100 °/sec 100 °/sec
Max Speed - J3 150 °/sec 150 °/sec
Max Speed - J4 150 °/sec 150 °/sec
Max Speed - J5 180 °/sec 180 °/sec
Max Speed - J6 180 °/sec 180 °/sec
General S.A.E METRIC
Mounting Method Pedestal Mount Pedestal Mount
Wrist Flange Mounting Type ISO 9409-1-50-4M6 ISO 9409-1-50-4M6
Domestic Pallet 102.0 in x 75.0 in x 38.0 in 259 cm x 191 cm x 97 cm
Weight 1460 lb 1460 lb
Power Requirement 100-240 VAC 50-60Hz, 1-Phase 100-240 VAC 50-60Hz, 1-Phase
Need More Information?
HID3, 1-1/4" Diameter Complete Indexable Drill Kit, 3XD, Multiple Chip Breakers & Grades $556.95 $473.97
ER32 4mm Straight-Bore Collet, 4 - 3mm Clamping Range $18.95 $9.97
E06K-SCLCR2, 3/8" Ø Carbide Shank Internal (ID) Boring Bar, Right-Hand, Screw-Lock, Through-Tool Coolant $183.95 $119.97
