MILL TOOLHOLDING
HAAS TESTED. HAAS PROVEN.
SEE ALL MILL TOOLHOLDING KITS
  1. Component_Templates
  2. Matt_Test_Page
  3. Mill Toolholding
  • About Haas Tooling
  • Join Winner’s Circle
  • Today's Hot Deals
  • Mill Cutting Tools
  • Lathe Cutting Tools
  • Tombstones & Kits
  • Tool Management
  • Storage & Handling
All Haas Tooling Categories
Explore a comprehensive range of mill tool holders, including end mill holders, shell mill holders, shrink fit holders, ER collet chucks, pull studs, and hydraulic milling chucks. Whether you need secure clamping for end mills, shell mills, or specialized tooling, our diverse selection offers the reliability and versatility required for various milling applications.
103 41 39 41 41 41 items
75 38 38 38 38 38 items
112 57 57 57 57 57 items
87 61 61 61 61 61 items
26 14 14 14 14 14 items
5 2 2 2 2 2 items
38 24 24 18 24 18 items
76 43 43 43 43 43 items
33 17 17 17 17 17 items
20 20 20 20 20 20 items
3 items
HAAS TOOLING TIPS
TOOLHOLDER ESSENTIALS
If you’ve ever had questions about toolholders for your mill, or wondered which one suits your application the best, this video will help. In this Tip of the Day, Mark explains in-depth the different types of toolholders available, and discusses the key factors to consider – price, balance, grip, clearance, and runout – when selecting the toolholders for each job.
ER COLLET ESSENTIALS
Whether you’re a beginning or advanced machinist, you’ve probably wondered more than once if you’re using the correct collet. With so many to choose from – and often confusing sizes on the collets – it’s hard to know if you’re using the right one. In this valuable Tip of the Day, Mark looks at each type of collet, and explains how and when to use each one.
HUT-HEX-37/45-25, 37mm Ø Internal (ID) Hex Broaching Tool, 25mm Shank x 126mm Cut Depth, Neutral, Insert Size 37/45 $209.95 $146.97
