INDEXABLE DRILL BODIES
HAAS TESTED. HAAS PROVEN.
SEE ALL INDEXABLE DRILL BODIES
  2. Holemaking
  3. Indexable Drill Bodies
INDEXABLE DRILL BODY OVERVIEW
Indexable Drills
Indexable drills feature a tool steel body, and typically two inserts: a center insert that cuts the center of the hole, and a periphery insert that cuts the outside hole diameter. Inserts are usually secured to the tool body using screws, and when the cutting edge becomes dull, the insert is indexed to expose a new cutting edge.
NOTE: Indexable drill bodies require both periphery and center inserts. The styles are not interchangeable. Remember to order both periphery and center inserts.
        Features:
  • High penetration rates and lower chip friction
  • Less accurate than solid carbide
  • Higher initial cost, but lower long-term costs
  • Available in larger diameters than solid drills
  • Inserts can be changed without removing the tool from the holder
  • Can use the same drill for different materials by changing inserts
  • Less susceptible to breakage than solid carbide
  • Can also be used for boring, and facing operations
        Applications:
  • Medium- and large-diameter holes
  • Medium tolerance demands
  • Blind holes requiring a “flat” bottom
  • Plunge drilling operations
ISO MATERIAL TYPE
N - ALUMINUM / NON-FERROUS
S - HIGH-TEMP ALLOYS
CENTER INSERT
PERIPHERY INSERT
HA CHIP GROOVE
●  N
HL CHIP GROOVE
●  P
●  M
●  S
HM CHIP GROOVE
●  P
●  M
●  K
HP CHIP GROOVE
●  P
●  K
●  Primary Workpiece Material | ○  Secondary Workpiece Material
Videos
Sale Items( 1 )
System of Measurement( 2 )
[D1] Drill Diameter( 41 )
Insert Size( 6 )
Length / Diameter( 3 )
66 items
01-0022
HID3, 3/4" Ø Indexable Drill Body, 1" Shank, 3XD, Insert Size C, TSC
Part #: 01-0022
RETAIL PRICE:
167.97
01-0023
HID3, 7/8" Ø Indexable Drill Body, 1" Shank, 3XD, Insert Size C, TSC
Part #: 01-0023
RETAIL PRICE:
167.97
01-0024
HID3, 1" Ø Indexable Drill Body, 1" Shank, 3XD, Insert Size D, TSC
Part #: 01-0024
RETAIL PRICE:
01-0025
HID3, 1-1/8" Ø Indexable Drill Body, 1-1/4" Shank, 3XD, Insert Size D, TSC
Part #: 01-0025
RETAIL PRICE:
188.97
01-0026
HID3, 1-1/4" Ø Indexable Drill Body, 1-1/4" Shank, 3XD, Insert Size E, TSC
Part #: 01-0026
RETAIL PRICE:
01-0027
HID3, 1-3/8" Ø Indexable Drill Body, 1-1/4" Shank, 3XD, Insert Size E, TSC
Part #: 01-0027
RETAIL PRICE:
201.97
01-0028
HID3, 1-1/2" Ø Indexable Drill Body, 1-1/2" Shank, 3XD, Insert Size F, TSC
Part #: 01-0028
RETAIL PRICE:
01-0029
HID3, 1-5/8" Ø Indexable Drill Body, 1-1/2" Shank, 3XD, Insert Size F, TSC
Part #: 01-0029
RETAIL PRICE:
188.97
01-0030
HID3, 1-3/4" Ø Indexable Drill Body, 1-1/2" Shank, 3XD, Insert Size F, TSC
Part #: 01-0030
RETAIL PRICE:
201.97
01-0031
HID5, 3/4" Ø Indexable Drill Body, 1" Shank, 5XD, Insert Size C, TSC
Part #: 01-0031
RETAIL PRICE:
201.97
01-0032
HID5, 7/8" Ø Indexable Drill Body, 1" Shank, 5XD, Insert Size C, TSC
Part #: 01-0032
RETAIL PRICE:
201.97
01-0033
HID5, 1" Ø Indexable Drill Body, 1" Shank, 5XD, Insert Size D, TSC
Part #: 01-0033
RETAIL PRICE:
214.97
01-0034
HID5, 1-1/8" Ø Indexable Drill Body, 1-1/4" Shank, 5XD, Insert Size D, TSC
Part #: 01-0034
RETAIL PRICE:
214.97
01-0035
HID5, 1-1/4" Ø Indexable Drill Body, 1-1/4" Shank, 5XD, Insert Size E, TSC
Part #: 01-0035
RETAIL PRICE:
214.97
01-0036
HID5, 1-3/8" Ø Indexable Drill Body, 1-1/4" Shank, 5XD, Insert Size E, TSC
Part #: 01-0036
RETAIL PRICE:
200.97
01-0037
HID5, 1-1/2" Ø Indexable Drill Body, 1-1/2" Shank, 5XD, Insert Size F, TSC
Part #: 01-0037
RETAIL PRICE:
235.97
01-0443
HID5, 13/16" Ø Indexable Drill Body, 1" Shank, 5XD, Insert Size C, TSC
Part #: 01-0443
RETAIL PRICE:
201.97
01-0549
HID3, 20mm Ø Indexable Drill Body, 25mm Shank, 3XD, Insert Size C, TSC
Part #: 01-0549
RETAIL PRICE:
157.97
2799.97
833.97
111.97
503.97
1175.97
01-0550
HID3, 23mm Ø Indexable Drill Body, 25mm Shank, 3XD, Insert Size C, TSC
Part #: 01-0550
RETAIL PRICE:
157.97
2949.97
877.97
117.97
530.97
1238.97
01-0551
HID3, 25mm Ø Indexable Drill Body, 32mm Shank, 3XD, Insert Size D, TSC
Part #: 01-0551
RETAIL PRICE:
157.97
