UMC-500
  1. Vertical Mills
  2. Universal Machines
  3. UMC-500
UMC-500
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
5-Axis CNC Vertical Machining Center with 24" x 16" x 16" travels
5-axis machining is an effective means to reduce setups and increase accuracy for multi-sided and complex parts. The shorter travels and compact footprints of the Haas UMC-500 Series Universal Machining Centers make them perfect solutions for 3+2 machining and simultaneous 5-axis machining of smaller parts.
NOTE: The 95-gallon (360 L) coolant tank option requires a hopper-style chip bin to clear the tank and reach the chip conveyor discharge outlet.
  • 5-axis simultaneous machining
  • Powerful inline direct-drive spindle
  • Large capacity side-mount tool changer
  • Includes Wireless Intuitive Probing System
See Available Stock
Current Lead Time
  • 40 Taper
  • 5 Axis
  • 8.1k RPM
  • 30+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
120+1 Side-Mount Tool Changer
DOWNLOAD BROCHURE
HAAS JOURNAL
    Compare Machines
    BUILD & PRICE
    Contact Distributor
    • Build-&-Price
    • Specs
    • Automation
    • Details
    • Machine Info
    Travels S.A.E METRIC
    X Axis 24.00 in 610 mm
    Y Axis 16.00 in 406 mm
    Z Axis 16.00 in 406 mm
    Spindle Nose to Platter (~ max) 20.0 in 508 mm
    Spindle Nose to Platter (~ min) 4.0 in 102 mm
    Spindle S.A.E METRIC
    Max Rating 30.0 hp 22.4 kW
    Max Speed 8100 rpm 8100 rpm
    Max Torque 90.0 ft-lbf @ 2000 rpm 122.0 Nm @ 2000 rpm
    Taper CT40 | BT40 | HSK-A63 CT40 | BT40 | HSK-A63
    Bearing Lubrication Air / Oil Injection Air / Oil Injection
    Cooling Liquid Cooled Liquid Cooled
    B Axis - Tilt S.A.E METRIC
    Travel 120 ° to 35- ° 120 ° to 35- °
    Max Speed 50 °/sec 50 °/sec
    Torque (Continuous) 1854 ft-lbf 2514 Nm
    Brake Torque 900 ft-lbf 1220 Nm
    C Axis - Rotation S.A.E METRIC
    Travel 360 ° 360 °
    Max Part Swing 18.0 in 457 mm
    Platter S.A.E METRIC
    Platter Diameter 15.70 in 400 mm
    Max Weight on Platter 500 lb 226.8 kg
    Max Weight on Platter w/Pallet Pool 200 lb 90.7 kg
    T-Slot Width 0.626 in to 0.630 in 15.90 mm to 16.00 mm
    Number of Std T-Slots 5 5
    T-Slot Center Distance 2.48 in 63 mm
    Feedrates S.A.E METRIC
    Max Cutting 650 ipm 16.5 m/min
    Rapids on X 900 ipm 22.9 m/min
    Rapids on Y 900 ipm 22.9 m/min
    Rapids on Z 900 ipm 22.9 m/min
    Axis Motors S.A.E METRIC
    Max Thrust X 2750 lbf 12233 N
    Max Thrust Y 2750 lbf 12233 N
    Max Thrust Z 3400 lbf 15124 N
    Tool Changer S.A.E METRIC
    Type SMTC SMTC
    Capacity 30+1 30+1
    Max Tool Diameter (full)** 2.5 in 64 mm
    Max Tool Diameter, Large (adjacent empty)** 5.0 in 127 mm
    Max Tool Length (from gage line) 12.00 in 305 mm
    Max Tool Weight 12.0 lb 5.4 kg
    Tool-to-Tool (avg) 2.80 s 2.80 s
    Chip-to-Chip (avg) 3.60 s 3.60 s
    General S.A.E METRIC
    Coolant Capacity 55 gal 208 L
    Inline Air Hose 3/8 in 3/8 in
    Coupler (Air) 3/8 in 3/8 in
    Spindle Speed 8100 rpm 8100 rpm
    Spindle Power 30.0 hp 22.4 kW
    Domestic Pallet 128.0 in x 98.0 in x 110.0 in 325 cm x 249 cm x 279 cm
    Export Pallet 128.0 in x 92.0 in x 101.0 in 325 cm x 234 cm x 257 cm
    Export Crate 128.0 in x 101.0 in x 123.0 in 325 cm x 257 cm x 312 cm
    Weight 11900 lb 5400.0 kg
    Domestic Pallet w/Conveyor & 70+1 SMTC 128.0 in x 98.0 in x 120.0 in 325 cm x 249 cm x 305 cm
    Export Crate w/Conveyor & 70+1 SMTC 128.5 in x 101.0 in x 141.5 in 326 cm x 257 cm x 359 cm
    Weight w/Conveyor & 70+1 SMTC 13,320 lb 6,042.0 kg
    Domestic Pallet w/Conveyor & 120+1 SMTC 131.0 in x 20.0 in x 108.5 in 333 cm x 51 cm x 276 cm
    Weight w/Conveyor & 120+1 SMTC 13,960 lb 6,332.0 kg
    Export Pallet w/Conveyor & 120+1 SMTC 133.5 in x 22.5 in x 120.0 in 339 cm x 57 cm x 305 cm
    NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
    *Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
    Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
    **Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
    ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
    † Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
    Standard Features
    • 8100-rpm Spindle
    • 30+1 Side-Mount Tool Changer
    • Wireless Intuitive Probing System
    • 55-Gallon Coolant Tank
    • Multi-Stage Coolant Pump
    • Control Widescreen Monitor
    • Large Remote Jog Handle with Touchscreen Display
    • Ethernet Interface
    • CNC Control Cabinet Cooler
    • Power Surge Protection
    • Second Home Position
    • Advanced Tool Management
    • Media Display M-Code; M130
    • Safe Run
    • HaasDrop
    • Dynamic Work Offsets and Tool Center Point Control
    • Rigid Tapping
    • ECO Mode
    • Rotary Scales
    • Top Cover for UMC Series
    • Phone Charging Stand
    • Rectangle Grid Fixture Plate, UMCs
    Warranty
    • 1-Year Standard Warranty
    Available Options
    Automation Options
    ANSWERS TO YOUR CONCERNS ABOUT ADDING A HAAS ROBOT: It won’t take up much space, cost a ton of money, or take weeks to integrate.
    SPACE EFFICIENT
    COST EFFECTIVE
    EASY TO INTEGRATE
    EASY TO LEARN
    10+1 or 20+1 Pallet Pool
    Add a pallet pool to your UMC-500 or UMC-500SS to take your production to the next level. With 10 or 20 additional pallets, you can ensure your machine will be running “lights out.”
    10-STATION
    20-STATION
    AUTOMATE YOUR PRODUCTION!
    The Haas Automatic Parts Loader is a simple and affordable way to automate part production and boost productivity. It is designed and built exclusively for the UMC-500 and UMC-500SS, and connects directly to the Haas control.
    LEARN MORE
    A Top-Down Comparison
    Overview
    The UMC-500 offers shorter travels and a more compact footprint than the UMC-750, while incorporating the design improvements of the larger UMC-1000.
    Universal Machining Center Design Improvements:
    • Cycloidal Rotary Drives
    • Lighter Operator Door
    • Front-Mounted Control Pendant
    • Easy-Access Operator Convenience Features
    • Larger Side-Window
    • Stiffer Base Casting
    • Standard Rollaway Coolant Tank
    The cycloidal rotary drive system – designed for machine tools and robotics – provides a great combination of speed, accuracy, and durability on both the B and C axes. The rugged design provides long service life, with little or no maintenance, and is especially durable in a crash. The cycloidal rotary drive can be back driven to absorb energy from an impact. The shock-load capacity is 5 times the rated torque of the gearbox, and the entire gearbox is a simple drop-in replacement, should damage occur.
    Operator Door Improvements
    The UMC-500 door mounts inside the enclosure, which raises the bottom of the enclosure opening, and provides better chip control.
    Control Pendant Mount
    The internal mounting design of the UMC-500 door allows the control pendant to be mounted to the front of the machine, in an operator-friendly position.
    The UMC-500’s operator convenience features are mounted to the front of the machine for easy access, including a toolholder storage rack, work table, toolholder vise, storage tray, and washdown hose.
    Side-Window Design
    Moving the control pendant to the front of the UMC-500 allowed us to enlarge the side window and make it slide open. This provides access to the machine’s platter, and also allows a pallet pool or other automation to be added to the machine.
    Base Casting and Coolant Tank
    The UMC-500 base casting is stiff and compact, improving cut performance, and allowing the use of our standard 55-gallon (208 liter) rollaway coolant tank, for easy cleaning and maintenance. The coolant tank also accepts our Oil Skimmer and Coolant Refill options to further enhance productivity.
    AVAILABLE OPTIONS
    VIDEOS
    CUSTOMER TESTIMONIALS
    RELATED PRODUCTS
    Standard Features
    • 8100-rpm Spindle
    • Safe Run
    • HaasDrop
    • Rigid Tapping
    • ECO Mode
    • Rotary Scales
    Warranty
    Available Options
    Automation Options
    10-STATION
    20-STATION
    • 3D Model w/SMTC-120 (ZIP)
    • 3D Model | 10+1 Pallet Pool (ZIP)
    • 3D Model | 20+1 Pallet Pool (ZIP)
    • Installation Guide
    • Layout Drawing
    • CDF Conveyor Layout Drawing
    • SMTC-120 Footprint Drawing
    • Torque Chart
    • Operator’s Manual
    • UMC SERIES FLYER
    • Automatic Workholding and Configuration Chart
    • Automation Options And Configurations chart
    UMC COMPARISON – Work Envelope ≠ Machine Travels
    In 5-axis machining, your part and workholding must be able to rotate and tilt within the workspace, allowing you to reach all areas of the part, without interference or collisions. This yields a cylindrical work envelope that is smaller than the machine travels.
    DOWNLOAD COMPARISON
    HAAS VISE OPTIONS AND CONFIGURATIONS CHART
    AIR VISES | HYDRAULIC VISES
    VIDEOS
    5-Axis vs. 3-Axis Machining
    Which machine is right for the job? See what it takes to machine a multisided part on both a 3-axis and 5-axis machine. Jon Nelson walks you through the workholding, tooling, and setups needed for both machining types for cutting complex parts.
    UMC-500 Machine Overview
    The Haas UMC-500 combines the 5-axis capability of our industry-leading UMC-750, with the design improvements of our larger UMC-1000, to create powerful 5-axis solution with a footprint just slightly larger than a VF-2.
    LEARN MORE
    Actron Engineering
    “The UMC-750 and 500 allow us to rotate the part in such a way that we can go in and do deep pocketing work using longer tools.”
    – John Staszewski, President, Actron Engineering
    Rimeco Products
    “We specialize in aerospace and defense parts. Our Haas machines allow us to do high-speed machining. When we got our first UMC-500, we realized we could add our quick clamp system, which was invented by my dad and uncle, onto that UMC, just by modifying it a little bit so the air comes in a little differently. There is a rotary swivel on it, and now we can take our fixtures that we’ve been using for 20 years and put them right on our UMC-500, and continue to machine just as we have in the past, but now with the capability of the 5-axis, it’s just more efficient.”
    – John Ribic, President
    Cat-Wood Metalworks
    “The versatility of the UMC-500SS is untouchable. It has saved us so much time with our operations. That is why we have 3 of them now. I ran a very familiar job on our first 5-axis, and after seeing how easy it was, that is when we bought two more. With the probing and tool break checks, you don’t have to check on the machine until it’s done. With the 5-axis machines, we’re doing the same amount of work, we’re just getting it done a lot faster.”
    – A.J Rolling, Owner
    Hyperion Technology Group
    Hyperion Technology Group specializes in advanced sensory equipment for military and commercial applications. Manufacturing key components in-house for the systems they engineer has been a key part of their success, and in that effort, they consider Haas one of their partners.
    Today, Hyperion’s machine shop is filled exclusively with Haas CNCs, including a UMC-500SS 5-axis universal machining center, a VF-6SS large-capacity vertical machining center, and two medium-capacity milling machines, a VF-3SS and VF-4SS. They also have a Haas TL-2 toolroom lathe.
    Holzman Machine
    Holzman Machine, LLC found its niche machining complex 5-axis parts for aerospace using Haas UMC 5-axis machining centers. Recently, they took their 5-axis production to the next level by adding a UMC-500 integrated with an Automatic Parts Loader to run stainless steel parts lights-out and on weekends.
    Customer Spotlight - Pragmatic Manufacturing
    Having purchased more than 20 Haas CNCs in a former business venture, the management team at Pragmatic Manufacturing decided to standardize on Haas mills and lathes from day one. Now celebrating 5 years in business, Pragmatic Manufacturing has become a leader in serving the aerospace and defense industries.
    Customer Spotlight - Straton Industries
    Straton Industries has been using Haas CNC machine tools for the last 5 years to machine parts for aerospace and space exploration. They started with a UMC-750 5-axis universal machining center, and have since added five more Haas machines, including two UMC-500SS 5-axis universal machining centers, two EC-1600ZT horizontal machining centers, and an ST-20Y turning center.
    RELATED PRODUCTS
    LARGER WORK ENVELOPE
    Haas UMC-750
    UMC-750
    5-Axis CNC Vertical Mill with 30" x 20" x 20" travels
    • 40 Taper
    • 5 Axis
    • 8.1k RPM
        CNY ONLY
    Learn More Build & Price
    DIFFERENT APPROACH
    Haas VF-2TR
    VF-2TR
    Trunnion CNC Vertical Mill with 30" x 16" x 20" travels
    • 40 Taper
    • 5 Axis
    • 8.1k RPM
        CNY ONLY
    HIGHER PRODUCTION
    Haas UMC-500
    UMC-500SS
    Super-Speed 5-Axis CNC Vertical Machining Center with 24" x 16" x 16" travels
    • 40 Taper
    • 5 Axis
    • 12k RPM
        CNY ONLY
    Build & Price
    Get Started
    Need More Information?
