Pallet Pool, 10-Station (PALLET POOL-10 STN)
Product Image
GET QUOTE
10+1 Pallet Pool, UMC
    CNY ONLY
High-volume production, unattended operation
  • 10+1 Stations
  • 15.75" x 11.75" Pallet Size
  • Option Info
  • Details
  • Specs
OVERVIEW
CUSTOMER TESTIMONIALS
AVAILABLE ON THESE MACHINES
OTHER PALLET POOLS
Our 10+1 pallet pool for the UMC-500/SS, UMC-750/SS, and UMC-1000/SS is perfect for high-volume production runs, or high-mix/low-volume machining. The pallets can be scheduled individually according to priority and sequencing requirements, allowing high-priority parts to be machined first or staged more often. Completed pallets are returned automatically to the holding location, or can be sequenced to a protected operator station for immediate unloading and re-loading.
NOTE: Requires optional 50+1, 70+1 , or 120+1 side-mount tool changer. The Pallet Pool must be anchored for proper operation.
The UMC-500 and UMC-500SS require a hopper-style chip bin to clear the 95-gallon (360 L) coolant tank.
UMC-500/SS Work Envelope: 16" dia. x 16" tall (406 x 406 mm)
UMC-750/SS and UMC-1000/SS Work Envelope: 16" dia. x 21" tall (406 x 533 mm)
  • 10+1 pallets (10 storage locations + 1 machining station)
  • 200 lb (90 kg) max payload per pallet (workpiece + workholding)
  • Fully integrated solution for lights-out production
  • Easy-to-use scheduling interface in the Haas control
  • Dedicated load/unload station
    • Installation Guide
    • Owner’s Manual
    • Layout Drawing UMC-500
    • Layout Drawing UMC-750
    • Layout Drawing UMC-1000
    • Automation Options And Configurations chart
    SERVICE DOCUMENTS
    Customer Spotlight - Clippard Instrument Lab - Adding a Pallet Pool
    Clippard Instrument Lab of Cincinnati, Ohio, recently received a Haas UMC-500 with a Pallet Pool, so their single-shift shop could run the machine unattended overnight. Operations Manager Robin Rutschilling explains how the 16-station pallet pool allowed them to reduce handling times, as well as increase productivity.
    Haas UMC-500
    UMC-500
    5-Axis CNC Vertical Machining Center with 24" x 16" x 16" travels
    • 40 Taper
    • 5 Axis
    • 8.1k RPM
    • 30+1 Tool Capacity
        CNY ONLY
    Learn More Build & Price
    Haas UMC-500
    UMC-500SS
    Super-Speed 5-Axis CNC Vertical Machining Center with 24" x 16" x 16" travels
    • 40 Taper
    • 5 Axis
    • 12k RPM
        CNY ONLY
    Haas UMC-750
    UMC-750
    5-Axis CNC Vertical Mill with 30" x 20" x 20" travels
    • 40 Taper
    • 5 Axis
    • 8.1k RPM
        CNY ONLY
    Haas UMC-750SS
    UMC-750SS
    Super-Speed 5-Axis CNC Vertical Mill with 30" x 20" x 20" travels
    • 40 Taper
    • 5 Axis
    • 12k RPM
        CNY ONLY
    Haas UMC-1000
    UMC-1000
    5-Axis CNC Vertical mill with 40" x 25" x 25" travels
    • 40 Taper
    • 5 Axis
    • 8.1k RPM
        CNY ONLY
    Haas UMC-1000
    UMC-1000SS
    Super-Speed 5-Axis CNC Vertical Mill with 40" x 25" x 25" travels
    • 40 Taper
    • 5 Axis
    • 12k RPM
        CNY ONLY
    OTHER PALLET POOLS
    Product Image
    Pallet Pool, 6-Station
    • 6+1 Stations
    • 22" x 22" Pallet Size
        CNY ONLY
    Product Image
    Pallet Pool, 20-Station
    • 20+1 Stations
    • 8" x 8" Pallet Size
        CNY ONLY
    Product Image
    Pallet Pool, Small VMC
    • 3+1 Stations
    • 36" x 18" Pallet Size
        CNY ONLY
    Product Image
    Pallet Pool, VC-400/SS
    • 6+1 Stations
    • 22" x 14.5" Pallet Size
        CNY ONLY
    Product Image
    Pallet Pool, EC
    • 6+1 Stations
    • 400 mm Pallet Size
        CNY ONLY
    UMC Pallet Pool Overview
    The Pallet Pool option available on Haas UMC-Series Universal Machining Centers is designed for high-volume production and unattended operation. This manufacturing solution also excels at high-mix/low-volume part runs, because the user can assign a specific part program for each pallet. Each time that pallet is moved into the machining area, the control will automatically call the assigned part program.
    UMC Pallet Schedule Table
    Pallet Schedule Table Interface
    The simplified Pallet Schedule Table (PST) controls pallet scheduling functions from a dedicated screen. Pallets can be scheduled individually according to priority and sequencing requirements.
    • Each Pallet is identified with a number (1 through 11), and each storage location within the Pallet Pool and machine is identified with a letter (A through K). The storage locations do not change, but the pallet ID numbers move, so you can quickly see where any pallet is at any time. Translucent numbers indicate a pallet’s destination, while the pallet pool is in motion.
    • The LOAD ORDER column indicates the scheduled priority of each pallet. Schedule pallets by pressing the Pallet Schedule button at the load station on the pallet pool, by pressing the F2 key while the desired pallet is highlighted on the PST, or by simply entering a number in the LOAD ORDER column for that pallet.
    • Highlight the PROGRAM NAME column for a pallet, and press ENTER to navigate the programs list and select which program to run each time that pallet is loaded into the machine.
    • One-Touch function keys from the PST simplify common tasks when operating the machine.
      • Press ALTER to load the highlighted pallet into the machine and activate its designated program.
      • Press INSERT to run the active program. This button starts the cycle in “Pallet Mode.” Pallet Mode will interpret an M199 code as: “load the next-scheduled pallet, and run its assigned program” (see below).
      • Press F2 to schedule the highlighted pallet.
      • Press F3 to send the pallet on the Load Station (Shelf A) to an empty station in the pallet pool.
      • Press F4 to bring the highlighted pallet to the Load Station (Shelf A).
    We developed a new M-code for use with Automatic Pallet Changers. M199 is typically used at the end of a program. When the program is started by pressing [CYCLE START] in Memory mode, the M199 acts exactly like an M30 (Program End and Reset). But if the program is started by pressing [INSERT] while the Pallet Schedule Table is displayed (PALLET MODE), the M199 will command a pallet change to load the next scheduled pallet, and then run the program associated with that pallet. This allows the user to start machining on any pallet, even a mid-program start, and continue uninterrupted machining as long as pallets are scheduled.
    Domestic Pallet 135.0 in x 92.0 in x 90.0 in 343 cm x 234 cm x 229 cm
    Export Pallet 135.0 in x 92.0 in x 90.0 in 343 cm x 234 cm x 229 cm
    Weight 5220 lb 2368.0 kg
    Pallet Changer S.A.E METRIC
    Number of Stations 10 + 1 10 + 1
    Pallet Quantity 11 11
    Pallet Length 15.75 in 400 mm
    Pallet Width 11.75 in 298 mm
    Max Pallet Load 200 lb 90.7 kg
    Max Part Diameter (workholding + workpiece) 16.0 in 406 mm
    Need More Information?
