Pallet Pool, VC-400/SS (PALLET POOL-VC-400)
Product Image
GET QUOTE
6+1 Pallet Pool, VC-400/SS
    CNY ONLY
High-volume production, unattended operation
  • 6+1 Stations
  • 22" x 14.5" Pallet Size
* Available for order with a new VC-400/SS only.
  • Option Info
  • Details
  • Specs
OVERVIEW
VIDEOS
AVAILABLE ON THESE MACHINES
OTHER PALLET POOLS
Our 6+1 pallet pool for the VC-400/SS is perfect for high-volume production runs, or high-mix/low-volume machining. The pallets – 22" x 14.5" (559 x 368 mm) with T-slots – can be scheduled individually according to priority and sequencing requirements, allowing high-priority parts to be machined first or staged more often. Completed pallets are returned automatically to the holding location, or can be sequenced to a protected operator station for immediate unloading and re-loading.
NOTE: Requires optional 50+1 side-mount tool changer. The Pallet Pool must be anchored for proper operation. Not available for field installation.
  • Work Envelope: 22" width x 16" depth (559 x 406 mm)
  • Pallet Size: 22" x 14.5" (559 x 368 mm)
  • 6+1 pallets (6 storage locations + 1 machining station)
  • 500 lb (227 kg) max payload per pallet (workpiece + workholding)
  • Fully integrated solution for lights-out production
  • Easy-to-use scheduling interface in the Haas control
  • Dedicated load/unload station
  • Must be ordered with the machine
  • Installation Guide
  • Layout Drawing
  • Owner’s Manual
  • Automation Options And Configurations chart
SERVICE DOCUMENTS
PRODUCT SPOTLIGHT: VC-400 6+1 PALLET POOL
The 6+1 Pallet Pool provides high production capabilites to VC-400 machining. Easy integration allows you to set up jobs on one pallet, while you’re running parts on another pallet. This Pallet Pool allows for your machine to run unattended operations for longer.
NOTE: The Pallet Pool requires the optional 50+1 side-mount tool changer. Not field installable. Must be ordered with a new VC-400.
 BOOST YOUR PRODUCTIVITY
Whether you’re doing high-volume production runs, high-mix/low volume machining, or just want to run lights-out, this fully integrated 6+1 pallet pool will boost the productivity of your VC-400.
Haas EC-400
VC-400
Twin-Pallet VMC with 22" x 16" x 20" (559 x 406 x 508 mm) travels
  • 40 Taper
  • 3 Axis
  • 8.1k RPM
  • 30+1 Tool Capacity
    CNY ONLY
Learn More Build & Price
Haas VC-400
VC-400SS
Super-Speed Twin-Pallet VMC with 22" x 16" x 20" (559 x 406 x 508 mm) travels
  • 40 Taper
  • 3 Axis
  • 12k RPM
    CNY ONLY
OTHER PALLET POOLS
Product Image
Pallet Pool, 6-Station
  • 6+1 Stations
  • 22" x 22" Pallet Size
    CNY ONLY
Product Image
Pallet Pool, 20-Station
  • 20+1 Stations
  • 8" x 8" Pallet Size
    CNY ONLY
Product Image
Pallet Pool, Small VMC
  • 3+1 Stations
  • 36" x 18" Pallet Size
    CNY ONLY
Product Image
Pallet Pool, 10-Station
  • 10+1 Stations
  • 15.75" x 11.75" Pallet Size
    CNY ONLY
Product Image
Pallet Pool, EC
  • 6+1 Stations
  • 400 mm Pallet Size
    CNY ONLY
VC Series Pallet Pool Overview
The Pallet Pool option available on Haas VC Series vertical machining centers is designed for high-volume production and unattended operation. This manufacturing solution also excels at high-mix/low-volume part runs, because the user can assign a specific part program for each pallet. Each time that pallet is moved into the machining area, the control will automatically call the assigned part program.
  • Not available for field installation
  • Must be ordered with machine
  • Ergonomic loading station
  • Manual pallet rotation for easy part loading and unloading
Pallet Pool Specifications
  INCH METRIC
Number of Stations 6 + 1 6 + 1
Number of Pallets (includes the 2 pallets from the machine)
Pallet Length
22.0 in 559 mm
Pallet Width
14.5 in
368 mm
Maximum Pallet Load (Workholding + Workpiece)
500 lb
226.8 kg
Maximum Part Length (Centered on Pallet) may vary if part is narrower than maximum 35.0 in
889 mm
Maximum Part Width (Centered on Pallet) may vary if part is shorter than maximum 12.0 in 305 mm
Pallet Schedule Table
Pallet Schedule Table Interface
The simplified Pallet Schedule Table (PST) controls pallet scheduling functions from a dedicated screen. Pallets can be scheduled individually according to priority and sequencing requirements.
  • Each Pallet is identified with a number (1 through 6), and each storage location within the Pallet Pool and machine is identified with a letter (A through H). The storage locations do not change, but the pallet ID numbers move, so you can quickly see where any pallet is at any time. Translucent numbers indicate a pallet’s destination, while the pallet pool is in motion.
  • The LOAD ORDER column indicates the scheduled priority of each pallet. Schedule pallets by pressing the Pallet Schedule button at the load station on the pallet pool, by pressing the F2 key while the desired pallet is highlighted on the PST, or by simply entering a number in the LOAD ORDER column for that pallet.
  • Highlight the PROGRAM NAME column for a pallet, and press ENTER to navigate the programs list and select which program to run each time that pallet is loaded into the machine.
  • One-Touch function keys from the PST simplify common tasks when operating the machine.
    • Press ALTER to load the highlighted pallet into the machine and activate it's designated program.
    • Press INSERT to run the active program. This button starts the cycle in “Pallet Mode.” Pallet Mode will interpret an M199 code as: “load the next-scheduled pallet and run its assigned program” (see below).
    • Press F2 to schedule the highlighted pallet.
    • Press F3 to send the pallet on the Load Station (Shelf A) to an empty station in the pallet pool.
    • Press F4 to bring the highlighted pallet to the Load Station (Shelf A).
We developed a new M-code for use with Automatic Pallet Changers. M199 is typically used at the end of a program. When the program is started by pressing [CYCLE START] in Memory mode, the M199 acts exactly like an M30 (Program End and Reset). But if the program is started by pressing [INSERT] while the Pallet Schedule Table is displayed (PALLET MODE), the M199 will command a pallet change to load the next scheduled pallet, and then run the program associated with that pallet. This allows the user to start machining on any pallet, even a mid-program start, and continue uninterrupted machining, as long as pallets are scheduled.
Pallet Changer S.A.E METRIC
Pallet Quantity 7 7
Pallet Length 22.00 in 559 mm
Pallet Width 14.50 in 368 mm
Max Pallet Load 500 lb 226.8 kg
Max Part Size (workholding + workpiece) 22.00 in x 16.00 in 559 mm x 406 mm
Domestic Pallet 180.0 in x 92.0 in x 92.0 in 457 cm x 234 cm x 234 cm
Export Pallet 182.0 in x 94.0 in x 98.0 in 462 cm x 239 cm x 249 cm
Weight 6260 lb 2839.0 kg
Need More Information?
