Pallet Pool, 6-Station (PALLET POOL-6 STN)
Product Image
GET QUOTE
6+1 Pallet Pool, UMC
    CNY ONLY
High-volume production, unattended operation
  • 6+1 Stations
  • 22" x 22" Pallet Size
  • Option Info
  • Specs
OVERVIEW
AVAILABLE ON THESE MACHINES
OTHER PALLET POOLS
Our 6+1 pallet pool for the UMC-1250/SS is perfect for high-volume production runs, or high-mix/low-volume machining. The pallets can be scheduled individually according to priority and sequencing requirements, allowing high-priority parts to be machined first or staged more often. Completed pallets are returned automatically to the holding location, or can be sequenced to a protected operator station for immediate unloading and re-loading.
NOTE: Requires optional 50+1 or 70+1 side-mount tool changer. The Pallet Pool must be anchored for proper operation.
  • Work Envelope: 30" dia. x 24" tall (762 x 610 mm)
  • 6+1 pallets (6 storage locations + 1 machining station)
  • 500 lb (227 kg) max payload per pallet (workpiece + workholding)
  • Fully integrated solution for lights-out production
  • Easy-to-use scheduling interface in the Haas control
  • Dedicated load/unload station
  • Includes 95-gallon (360 L) coolant tank
  • Layout Drawing
  • Owner’s Manual
SERVICE DOCUMENTS
Available on These Machines
Haas UMC-1250
UMC-1250
5-Axis CNC Vertical mill with 50" x 30" x 28" travels
  • 40 Taper
  • 5 Axis
  • 8.1k RPM
  • 30+1 Tool Capacity
    CNY ONLY
Learn More Build & Price
Haas UMC-1250SS
UMC-1250SS
Super-Speed 5-Axis CNC Vertical Mill with 50" x 30" x 28" travels
  • 40 Taper
  • 5 Axis
  • 12k RPM
    CNY ONLY
OTHER PALLET POOLS
Product Image
Pallet Pool, 20-Station
  • 20+1 Stations
  • 8" x 8" Pallet Size
    CNY ONLY
Product Image
Pallet Pool, Small VMC
  • 3+1 Stations
  • 36" x 18" Pallet Size
    CNY ONLY
Product Image
Pallet Pool, 10-Station
  • 10+1 Stations
  • 15.75" x 11.75" Pallet Size
    CNY ONLY
Product Image
Pallet Pool, VC-400/SS
  • 6+1 Stations
  • 22" x 14.5" Pallet Size
    CNY ONLY
Product Image
Pallet Pool, EC
  • 6+1 Stations
  • 400 mm Pallet Size
    CNY ONLY
Pallet Changer S.A.E METRIC
Number of Stations 6 + 1 6 + 1
Pallet Quantity 7 7
Pallet Length 22.00 in 559 mm
Pallet Width 22.00 in 559 mm
Max Pallet Load 500 lb 226.8 kg
Max Part Diameter (workholding + workpiece) 30.0 in 762 mm
Max Part Height (workholding + workpiece) 24.0 in 610 mm
Domestic Pallet 173.0 in x 142.0 in x 90.0 in 439 cm x 361 cm x 229 cm
Export Pallet 173.0 in x 142.0 in x 94.0 in 439 cm x 361 cm x 239 cm
Weight 6700 lb 3039.0 kg
Need More Information?
