Pallet Pool, 3+1 VMC (PALLET POOL-VMC-SM)
Product Image
GET QUOTE
3+1 Pallet Pool for VF-2YT Series VMCs
    CNY ONLY
High-volume production, unattended operation
  • 3+1 Stations
  • 36" x 18" Pallet Size
  • Option Info
  • Specs
OVERVIEW
VIDEOS
AVAILABLE ON THESE MACHINES
OTHER PALLET POOLS
Our 3+1 pallet pool for the Haas VF-2YT Series VMCs is perfect for high-volume production runs, or high-mix/low-volume machining. The pallets – 36" x 18" (914 x 457 mm) with bolt-hole pattern – can be scheduled individually according to priority and sequencing requirements, allowing high-priority parts to be machined first or staged more often. Completed pallets are returned automatically to the holding location, or can be sequenced to a protected operator station for immediate unloading and re-loading.
NOTE: Requires a side-mount tool changer. The Pallet Pool must be anchored for proper operation. Not available for field installation.
  • Work Envelope: 30" width x 18" depth (762 x 457 mm)
  • 3+1 pallets (3 storage locations + 1 machining station)
  • 750 lb (340 kg) max payload per pallet (workpiece + workholding)
  • Fully integrated solution for lights-out production
  • Easy-to-use scheduling interface in the Haas control
  • Dedicated load/unload station
  • Must be ordered with the machine
  • 3D Model
  • INSTALLATION Guide
  • Layout Drawing
  • Automation Options And Configurations chart
SERVICE DOCUMENTS
VIDEOS
BOOST PRODUCTION ON VF-2YT SERIES MILLS
Have you ever wanted to boost the spindle uptime on your VF-2YT series VMC? The Haas VMC Pallet Pool increases spindle run time, and allows for unattended automation, so you can run more parts at the end of the day. Providing 4 total pallets (1 machining location and 3 storage locations), this pallet pool is a must-have for shops looking to boost throughput using small-footprint Haas VF-2YT series machines.
Haas VF-2YT
VF-2YT
CNC Vertical Mill with 30" x 20" x 20" travels
  • 40 Taper
  • 3 Axis
  • 8.1k RPM
  • 20 Tool Capacity
    CNY ONLY
Learn More Build & Price
Haas VF-2SSYT
VF-2SSYT
Super-Speed CNC Vertical Mill with 30" x 20" x 20" travels
  • 40 Taper
  • 3 Axis
  • 12k RPM
  • 30+1 Tool Capacity
    CNY ONLY
Haas VM-2
VM-2
CNC Vertical Mold Machine with 30" x 20" x 20" travels
  • 40 Taper
  • 3 Axis
  • 12k RPM
    CNY ONLY
OTHER PALLET POOLS
Product Image
6+1 Station Pallet Pool for VF-2YT Series
  • 6+1 Stations
    CNY ONLY
Product Image
5+1 Station Pallet Pool for Medium VFs
  • 5+1 Stations
  • 52" x 20" Pallet Size
    CNY ONLY
Product Image
UMC Pallet Pool, 6-Station
  • 6+1 Stations
  • 22" x 22" Pallet Size
    CNY ONLY
Product Image
UMC Pallet Pool, 20-Station
  • 20+1 Stations
  • 8" x 8" Pallet Size
    CNY ONLY
Product Image
UMC Pallet Pool, 10-Station
  • 10+1 Stations
  • 15.75" x 11.75" Pallet Size
    CNY ONLY
Product Image
Pallet Pool, VC-400/SS
  • 6+1 Stations
  • 22" x 14.5" Pallet Size
    CNY ONLY
Product Image
Pallet Pool, EC
  • 6+1 Stations
  • 400 mm Pallet Size
    CNY ONLY
Pallet Changer S.A.E METRIC
Number of Stations 3 + 1 3 + 1
Pallet Quantity 4 4
Pallet Length 36.00 in 914 mm
Pallet Width 18.00 in 457 mm
Max Pallet Load 750 lb 340.0 kg
Max Part Size (workholding + workpiece) 30.00 in x 18.00 in 762 mm x 457 mm
Domestic Pallet 183.0 in x 92.0 in x 92.0 in 465 cm x 234 cm x 234 cm
Export Crate 183.0 in x 94.0 in x 98.0 in 465 cm x 239 cm x 249 cm
Weight 6260 lb 2839.0 kg
Need More Information?
