Pallet Pool, 5+1 VMC (PALLET POOL-VMC-MD-5)
Product Image
GET QUOTE
5+1 Pallet Pool for VF-4 Series VMCs
    CNY ONLY
High-volume production, unattended operation
  • 5+1 Stations
  • 52" x 20" Pallet Size
  • Option Info
  • Specs
OVERVIEW
AVAILABLE ON THESE MACHINES
OTHER PALLET POOLS
Our 5+1 pallet pool for the Haas VF-4 Series VMCs is perfect for high-volume production runs, or high-mix/low-volume machining. The pallets – 52" x 20.35" (1321 x 517 mm) with bolt-hole pattern – can be scheduled individually according to priority and sequencing requirements, allowing high-priority parts to be machined first or staged more often. Completed pallets are returned automatically to the holding location, or can be sequenced to a protected operator station for immediate unloading and re-loading.
NOTE: Requires a side-mount tool changer. The Pallet Pool must be anchored for proper operation. Not available for field installation.
  • Work Envelope: 47.75" width x 20.35" depth (1213 x 517 mm)
  • 5+1 pallets (5 storage locations + 1 machining station)
  • 750 lb (340 kg) max payload per pallet (workpiece + workholding)
  • Fully integrated solution for lights-out production
  • Easy-to-use scheduling interface in the Haas control
  • Dedicated load/unload station
  • Must be ordered with the machine
  • 3D Model
  • INSTALLATION Guide
  • Layout Drawing
SERVICE DOCUMENTS
OTHER PALLET POOLS
Product Image
3+1 Pallet Pool, VF-2YT Series
  • 3+1 Stations
  • 36" x 18" Pallet Size
    CNY ONLY
Learn More Build & Price
Product Image
6+1 Pallet Pool, VF-2YT Series
  • 6+1 Stations
    CNY ONLY
Product Image
6+1 Pallet Pool, UMC-1250/SS
  • 6+1 Stations
  • 22" x 22" Pallet Size
    CNY ONLY
Product Image
20+1 Pallet Pool, UMC-500/SS
  • 20+1 Stations
  • 8" x 8" Pallet Size
    CNY ONLY
Product Image
10+1 Pallet Pool, UMC
  • 10+1 Stations
  • 15.75" x 11.75" Pallet Size
    CNY ONLY
Product Image
6+1 Pallet Pool, VC-400/SS
  • 6+1 Stations
  • 22" x 14.5" Pallet Size
    CNY ONLY
Product Image
6+1 Pallet Pool, EC-400
  • 6+1 Stations
  • 400 mm Pallet Size
    CNY ONLY
Pallet Changer S.A.E METRIC
Number of Stations 5 + 1 5 + 1
Pallet Quantity 6 6
Pallet Length 52.00 in 1321 mm
Pallet Width 20.35 in 517 mm
Max Pallet Load 750 lb 340.0 kg
Max Part Size (workholding + workpiece) 47.75 in x 20.35 in 1,213 mm x 517 mm
Weight for Sheet Metal Crate 700 lb 318 kg
Pallet 1, Pallet Pool 138.0 in x 91.5 in x 60.0 in 351 cm x 232 cm x 152 cm
Pallet 2, Pallet Pool 222.3 in x 91.5 in x 98.0 in 565 cm x 232 cm x 249 cm
Weight Pallet 2, Pallet Pool 4,860 lb 2,204 kg
Crate for Sheet Metal 66.0 in x 50.0 in x 29.0 in 168 cm x 127 cm x 74 cm
Weight Pallet 1, Pallet Pool 1,440 lb 653 kg
Need More Information?
