I/O PCB Hinge Door - Installation - AD0444
Service Home How To Procedures I/O PCB Hinge Door - Installation - AD0444
8.1 I/O PCB Hinge Door - Installation
Recently Updated Last updated: 02/26/2021
AD0444
This procedure will show you how to install the hinged door on the I/O PCB.
This Document Applies to the Following Kits:
93-1000297 DOOR, HINGED FOR I/O PCB
93-1000573 DOOR, HINGED CAN INSTALL KIT FOR I/O PCB
Open the control cabinet. Remove the cover for the I/O PCB.
Install the two socket head cap screws to the top and bottom hinge plate[1].
Install these parts:
  • Use (2) screws [2] to install the top hinge plate [1].
  • Use (2) screws [3] to install the bottom hinge plate [4].
  • Use (4) screws [5] to install the (2) door brackets [6].
  • door panel [F]
