DM-2
  1. Vertical Mills
  2. Drill/Tap/ Mill Series
  3. DM-2
DM-2
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
CNC Drill/Mill Center with 28" x 16" x 15.5" travels
The DM-2 is a compact, high-speed machining center built with proven Haas components and sub-assemblies. It is identical in construction and specifications to the DM-1, with the addition of 8" of X-axis travel and table length. The machine’s shop-proven 40-taper inline spindle, 18+1 tool changer, high acceleration rates, fast rapids, and impressive short tool-change times make the DM-2 an attractive high-productivity machining center.
The DM-2 allows shops to use their existing 40T tooling and enjoy the benefits of a larger spindle, and its lean-style, compact footprint makes very efficient use of valuable shop floor space.
  • More X-axis travel and longer table than the DM-1
  • Powerful 40-taper inline direct-drive spindle
  • High-productivity machining center with a compact footprint
See Available Stock
Current Lead Time
  • 40 Taper
  • 3 Axis
  • 10k RPM
  • 18+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
Compare Machines
BUILD & PRICE
Contact Distributor
  • Build-&-Price
  • Specs
  • Automation
  • Machine Info
  • Rotary Fit chart
Travels S.A.E METRIC
X Axis 28.00 in 711 mm
Y Axis 16.00 in 406 mm
Z Axis 15.50 in 394 mm
Spindle Nose to Table (~ max) 21.5 in 546 mm
Spindle Nose to Table (~ min) 6.0 in 152 mm
Spindle S.A.E METRIC
Max Rating 15.0 hp 11.2 kW
Max Speed 10000 rpm 10000 rpm
Max Torque 46.0 ft-lbf @ 1700 rpm 62.0 Nm @ 1700 rpm
Taper CT or BT 40 CT or BT 40
Bearing Lubrication Air / Oil Injection Air / Oil Injection
Cooling Air Cooled Air Cooled
Table S.A.E METRIC
Length 34.0 in 864 mm
Width 15.0 in 381 mm
T-Slot Width 0.626 in to 0.630 in 15.90 mm to 16.00 mm
T-Slot Center Distance 4.92 in 125 mm
Number of Std T-Slots 3 3
Max Weight on Table-100% Rapids (evenly dist.) 250 lb 113.4 kg
Max Weight on Table-50% Rapids (evenly dist.) 500 lb 226.8 kg
Feedrates S.A.E METRIC
Max Cutting 1200 ipm 30.5 m/min
Rapids on X 2400 ipm 61.0 m/min
Rapids on Y 2400 ipm 61.0 m/min
Rapids on Z 2400 ipm 61.0 m/min
Axis Motors S.A.E METRIC
Max Thrust X 2550 lbf 11343 N
Max Thrust Y 2550 lbf 11343 N
Max Thrust Z 4200 lbf 18683 N
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 18+1 18+1
Max Tool Diameter (full)** 2.5 in 64 mm
Max Tool Length (from gage line) 7.00 in 178 mm
Max Tool Weight 12.0 lb 5.4 kg
Tool-to-Tool (avg) 1.75 s 1.75 s
Chip-to-Chip (avg) 2.00 s 2.00 s
Tapping S.A.E METRIC
Max Tapping Speed 5000 rpm 5000 rpm
General S.A.E METRIC
Coolant Capacity 55 gal 208 L
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 10000 rpm 10000 rpm
Spindle Power 15.0 hp 11.2 kW
Domestic Pallet 91.0 in x 100.0 in x 98.0 in 231 cm x 254 cm x 249 cm
Export Pallet 91.0 in x 100.0 in x 98.0 in 231 cm x 254 cm x 249 cm
Weight 5350 lb 2427.0 kg
NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
*Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
**Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
† Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
Standard Features
  • 10,000-rpm Spindle
  • 18+1 Side-Mount Tool Changer
  • Variable Flow Coolant
  • 55-Gallon Coolant Tank
  • Single-Stage Coolant Pump
  • Control Widescreen Monitor
  • Ethernet Interface
  • Power Surge Protection
  • Advanced Tool Management
  • Media Display M-Code; M130
  • Safe Run
  • HaasDrop
  • Rigid Tapping
  • ECO Mode
  • Convenience Package
  • Phone Charging Stand
Warranty
  • 1-Year Standard Warranty
Available Options
Automation Options
ANSWERS TO YOUR CONCERNS ABOUT ADDING A HAAS ROBOT: It won’t take up much space, cost a ton of money, or take weeks to integrate.
SPACE EFFICIENT
COST EFFECTIVE
EASY TO INTEGRATE
EASY TO LEARN
AVAILABLE OPTIONS
VIDEOS
CUSTOMER TESTIMONIALS
RELATED PRODUCTS
Standard Features
  • Safe Run
  • HaasDrop
  • Rigid Tapping
  • ECO Mode
Warranty
Available Options
Automation Options
  • Installation Guide
  • Layout Drawing
  • TORQUE CHARTS
  • Operator’s Manual
  • DT/DM Series Flyer
  • Automation Options And Configurations chart
  • Automatic Workholding and Configuration Chart
HAAS VISE OPTIONS AND CONFIGURATIONS CHART
AIR VISES | HYDRAULIC VISES
VIDEOS
VMC Comparison
Watch as we show three of the most popular Haas mills run the same part, and see which machine finishes first.
Introducing the DM-1
The DM-1 Drill/Mill Center provides the same high speed and performance as our shop-proven DT-1 Drill/Tap Center, but with a larger 40-taper inline spindle and 18+1 tool changer.
Meet your new compact 5-axis
If you make small parts and have multiple setups, this rotary is the perfect solution. Lightning fast and accurate, the TRT100 fits in nearly every Haas mill, and will help you cut cycle times and boost your shop’s efficiency.
The DM-2 and DT-2
Bob and Bryan talk about the DM-2 and DT-2 Drill/Tap/Mill Centers, and show a great cutting demo that highlights the machines’ features, like 2400 ipm rapids and ultra-fast tool changes.
Customer Testimonials
MAJOR U.S. FIREARMS MANUFACTURER
“When we purchased our DM-2s, we thought we would decrease our cycle times by at least 25%, with the increased spindle speeds and rapids over our older box way machines. But in reality, with the faster rapids and spindle speeds, the decreased tool change and chip-to-chip times, and the speed and accuracy of the control, we have seen a decrease in cycle times by an average of 60%. With the repeatability of the machine and our setups, the amount of time it takes to get a first-piece approval has been reduced, resulting in an even greater percentage of gains in throughput. Thank you for an incredible machine!”
– A Major Southeast Firearms Manufacturer
RELATED PRODUCTS
MORE POWER
Product Image
VF-1
CNC Vertical Mill with 20" x 16" x 20" travels
  • 40 Taper
  • 3 Axis
  • 8.1k RPM
  • 20 Tool Capacity
    CNY ONLY
Learn More Build & Price
SMALLER SPINDLE TAPER
Haas DT-2
DT-2
CNC Drill/Tap Center with 28" x 16" x 15.5" travels
  • 30 Taper
  • 3 Axis
  • 10k RPM
  • 20+1 Tool Capacity
    CNY ONLY
FASTER SPINDLE
Haas VF-2SS
VF-2SS
Super-Speed CNC Vertical Mill with 30" x 16" x 20" travels
  • 40 Taper
  • 3 Axis
  • 12k RPM
  • 30+1 Tool Capacity
    CNY ONLY
HA2TS DM-2 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HA5C DM-2 POSITIVE FIT
HA5C2 DM-2 POSITIVE FIT
HA5C3 DM-2 POSITIVE FIT
HA5C4 DM-2 POSITIVE FIT
HA5CS DM-2 POSITIVE FIT
HRC160 DM-2 POSITIVE FIT
HRC210 DM-2 POSITIVE FIT
HRT160 DM-2 POSITIVE FIT
HRT160-2 DM-2 POSITIVE FIT
HRT160SP DM-2 POSITIVE FIT
HRT160SS DM-2 POSITIVE FIT
HRT210 DM-2 POSITIVE FIT
HRT210-2 DM-2 POSITIVE FIT
HRT210SP DM-2 POSITIVE FIT
HRTA5 DM-2 POSITIVE FIT
HRTA6 DM-2 POSITIVE FIT
T5C DM-2 POSITIVE FIT
TRT100 DM-2 POSITIVE FIT
TRT70 DM-2 POSITIVE FIT
HRT210HT DM-2 POSITIVE FIT
HRT100 DM-2 POSITIVE FIT
TH240 DM-2 POSITIVE FIT
HRT210SS DM-2 POSITIVE FIT
HA5C2-T DM-2 POSITIVE FIT
HA5C-T DM-2 POSITIVE FIT
HA5C3-T DM-2 POSITIVE FIT
HA5C4-T DM-2 POSITIVE FIT
LT260 DM-2 POSITIVE FIT
HRT200HS DM-2 POSITIVE FIT
HQDA5 DM-2 POSITIVE FIT
HQDA6 DM-2 POSITIVE FIT
HRT210S DM-2 POSITIVE FIT
HDD255 DM-2 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
Build & Price
Get Started
Need More Information?
