      • Serie VR
Servo Amplifier - Replacement - AD0280
Pagina iniziale Assistenza Procedure d’uso Amplificatore Servo - Sostituzione - AD0280
12.1 Amplificatore Servo - Sostituzione
Recently Updated Last updated: 08/23/2023
AD0280
Revisione B - 03/2026
Introduzione
Questa procedura spiega come rimuovere un amplificatore servo e installare un amplificatore servo intelligente.
Se si sostituisce un amplificatore servo effettuato prima del 2007, fare riferimento a Carico ausiliario PCB (AUX) - Sostituzione.
Il documento si applica a queste parti
  • 93-32-5549       AMP, 90A BL SMART
  • 93-32-5550J      AMP, 30A BL SMART
  • 93-32-5550N    AMP, 30A BL SMART
  • 93-32-3551J       AMP, 45A BL SMART
  • 93-32-3551N     AMP, 45A BL SMART
  • 93-32-5552G     AMP, 60A BL SMART
  • 93-4988       AMP,  60A BL SMART
  • 93-4989       AMP,  90A BL SMART
  • 93-5088       AMP, 30A DIGITAL AMP
  • 93-5089    AMP, AMPLIFICATORE DIGITALE 45 A
NOTA: Gli amplificatori digitali sono completamente compatibili con gli amplificatori intelligenti BL.
NOTA: Fare riferimento alla sezione Amplificatore Servo - Guida all'identificazione per ulteriori informazioni.
Sicurezza elettrica
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Sostituzione
Premere [POWER OFF].
Impostare l'interruttore principale sul [OFF] posizione.
Bloccare l'interruttore principale. Utilizzare un blocco approvato con un tag di sicurezza approvato.
pericolo: Se la spia dell'indicatore di tensione è accesa, non toccare i componenti elettrici. L'alta tensione nell'armadio elettrico può ucciderti. Attendere che il LED dell'indicatore di tensione si spengua completamente.
Scollegare i cavi dall'amplificatore servo usato. Rimuovere l'amplificatore servo usato.
Installare l'amplificatore servo intelligente sostitutivo [1].
Collegare il cavo di comando [2] corrente.
Collegare i cavi servo [3]. I cavi sono codificati a colori.
Collegare i ponticelli ad alta tensione [4] ai terminali dell'amplificatore servo adiacente.
