      • Gereedschapslade
      • Freesgereedschapslijpers
UMC C-Axis Rotary Encoder Ring - Replacement - AD0497
Service Home Instructieprocedure Zoekopdracht alarm: 4.103 UMC C-as roterende encoderring - Vervanging - AD0497
10.2 UMC ROTARY ENCODER RING - REPLACEMENT
Recently Updated Last updated: 06/13/2025
AD0497
Revision A 06/2025
This procedure details the replacement of the 3" C-Axis Encoder on all UMC machines and the 3" B-Axis Encoder on UMC -500/SS machines only.
Laser calibration is required to update the compensation table for the corresponding rotary axis following the encoder replacement.
This document applies to the following Service Kits:
  • 93-3923  ENCDR NON-CONT KIT 3"ID SER HI-RES
Used on B & C-Axis:
  • UMC-500/SS
Used on C-Axis:
  • UMC-750/SS
  • UMC-1000/SS
  • UMC-1250/SS
  • UMC-1500-DUO/SS
Tools Required:
  • 99-2130 ANTI-OXIDANT COMPOUND ELECTRICAL
  • 99-2147 DIELECTRIC GREASE PACK SUPER LUBE
  • 0.008" Mylar Shim
C-Axis Encoder Ring Replacement
: Warning: Only certified service personnel should perform this procedure. Reorientation of Z-pulse or Trip-Flag will require laser calibration to populate rotary compensation tables with new, correct, values.
Zero-return all Axis.
Press [EMERGENCY STOP].
Handle jog B to +120°.
Remove the C-Axis bottom cover.
Press [SETTING].
Navigate to the Rotaty tab.
Un-Check the 4th Axis.
Press [DIAGNOSTIC].
Navigate to Parameters > Factory.
Set 7.083 C-Axis Linear Scale Enabled to "Scale Disabled".
Power off the machine.
Uninstall the encoder read-head [1] by disconnecting the encoder cable [2] and removing the bolts and washers.
Note the Z-Pulse orientation before removing the encoder ring hub.
Uninstall the encoder ring hub [1] by removing the screws and washers mounting the encoder ring hub to the taper-lock.
Mount and loosely install the encoder ring hub [1] from the service kit with the provided hardware, SHCS 10-32 X 3/4 (x4) and WASHER #10 FLAT (x4).
Verify the Z-Pulse is in the same location as the ring that was uninstalled.
 Note: Do not torque mounting screws yet.
Turn on the machine.
Zero return all axis.
 Warning: Do not place the Mag Base anywhere near the Encoder.
Check and document the runout on the OD of the scale encoder ring hub using the upper-most diameter, as shown.
Adjust as necessary. TIR must be 0.0005" or less.
Torque the 4 bolts of the encoder ring hub to 30 in-lbf in the star pattern.
After torquing, double check the runout to verify the ring hub has not shifted.
Clean the back surface of the encoder read-head and the mounting surface.
Add a small amount of silicone dielectric grease to encoder cable connection [1]. Grease should be a thin layer, but cover all the pins.
Apply two small drops of anti-oxidant (99-2130) to the mounting surface on the read head in the locations shown [2].
Connect the encoder cable [4] to the encoder read-head.
Insert cable by carefully lining up electrical pins with cable connector.
Install the encoder read-head [1] from the service kit with the provided hardware,  SHCS 8-32 x 1/2 bolts (x2) [2] and Washer .17ID x .4OD (2x) [3].
Set the gap between the scale ring and read-head as shown [1] using the appropriate mylar shim (0.008").
 Note: Do not use a metal shim.
Starting on the left side of the read-head [2], torque the two read-head mounting bolts to 20 in-lbf.
After torquing, double check the gap with the shim to verify the read-head has not shifted.
Reinstall the C-Axis bottom cover being sure no tools, shims, etc. have been left in the casting.
13
Press [SETTING].
Check the 4th Axis.
Rotate the B-Axis back to zero when done.
14
Press [DIAGNOSTIC].
Navigate to Parameters > Configuration > Axis > B > Travel Limits.
Change: 6.108 B-Axis Positive Travel Limit from 180 to 110.
Press [DIAGNOSTIC].
Set 7.083 C-Axis Linear Scale Enabled to "Scale Linear".
Power cycle the machine.
16
Zero-Return the C-Axis.
Zero-Return All Axis.
Set new Tool Change offset by following the UMC - X and Y Axes - Tool Change Offsets and the Side-Mount Tool Changer - Z-Axis Tool Change Offset - NGC procedures.
17
Clear the Compensation table for the C-Axis.
Press [DIAGNOSTIC].
Navigate to Parameters > Compensation > C.
Press [ORIGIN].
To update compensation table values for the C-Axis a laser calibration is required. The calculated compensation values will then be entered into the C-Axis Compensation Table.
B-Axis Encoder Ring Replacement
 Note: These step apply only to the UMC-500/SS B-Axis.
Remove the bulkhead sheet metal [1] to access the B-Axis hard stop [2].
Rotate the B-Axis approximately 100 degrees, or until there is enough room to access the hard stop [1].
Remove the B-Axis hard stop [1].
Remove the two rear sheet metal panels [1] to access the B-Axis components.
Insert a service key and enter service mode.
Press [DIAGNOSTIC].
Change: 6.108 B-Axis Positive Travel Limit from 110 to 365.
Handle jog B to +180°.
Press [DIAGNOSTIC].
Set 6.083 B-Axis Linear Scale Enabled to "Scale Disabled".
Disconnect all of the cables and hoses [1] running to the C-Axis through the B-Axis encoder ring.
 Note: Mark the cables and hose to make reconnecting them easier later in this procedure.
Remove the corrugated conduit [2].
 Note: If the Z-Pulse is in the wrong location the B-Axis will not zero return correctly and can damage the cables and hoses.
Route all of the cables and hoses [1] for the C-Axis through the corrugated conduit [2] and through the B-Axis encoder ring.
Reconnect all of the cables and hoses to their original locations in the C-Axis.
13
 Note: The B-Axis should zero return in the Clockwise direction.
14
Connect the encoder cable [1] to the encoder read-head.
Install the encoder read-head [2] from the service kit with the provided hardware,  SHCS 8-32 x 1/2 bolts (x2) [4] and Washer .17ID x .4OD (2x) [3].
16
17
 Note: You will have to set a new tool change offset and update compensation table values for the B-Axis. This will require laser calibration.
18
Rotate the B-Axis to the same position when the hard stop was removed.
Install the B-Axis hard stop [1].
19
Press [DIAGNOSTIC].
Change: 6.108 B-Axis Positive Travel Limit from 365 to 110.
20
Press [DIAGNOSTIC].
Set 6.083 B-Axis Linear Scale Enabled to "Scale Linear".
21
Zero-Return the B-Axis.
22
Install the bulkhead sheet metal [1] once the B-Axis hard stop [2] has been installed.
23
Install the two rear sheet metal panels [1].
24
Clear the Compensation table for the B-Axis.
Press [DIAGNOSTIC].
Navigate to Parameters > Compensation > B.
Press [ORIGIN].
To update compensation table values for the B-Axis a laser calibration is required. The calculated compensation values will then be entered into the B-Axis Compensation Table.
