      • Frezarka do gniazd
      • Podajnik pręta Haas 12
      • Frezarki wspornikowe
      • Piły pionowe
      • Piła ukosowa
    • Obrabiarki kieszonkowe
      • Napędzane uchwyty tokarskie
      • Paleta narzędziowa
      • Torby na narzędzia
Paleta narzędziowa
Torby na narzędzia
Ostrzałki do narzędzi tnących
  2. Uchwyt roboczy frezarki
  3. Vise Kits
  4. 08-1903
Dotyczy tylko Europy
08-1903
Zestaw uchwytów roboczych do frezarki, imadło ręczne 150 mm, BT40
Nr części: 08-1903
MILL WORKHOLDING KIT, 150mm VISE, BT40
Cena: 999.95 ( / artykuł)
Cena: 4499.95 ( / artykuł)
Cena: 10499.95 ( / artykuł)
949.97
4274.97
9974.97
SETUPS MADE EASY
______________________________________________
BENEFITS:
This Mill Workholding Kit includes everything you need for basic workholding on a standard T-slot table. It contains a Single-Station Fixed-Jaw Vise, Toe Clamp Kit, Toolholder Fixture/Vise, and Machinable Soft Jaws.
The Single-Station Fixed-Jaw Vise is a flange-style vise that features a cast-in stationary jaw for less deflection and more stability during clamping. The proprietary AngLock® design ensures alignment of the moving jaw and reduces jaw lift for superior performance. The bolt-on jaws are easily changed or reversed, and machinable steel and aluminum soft jaws are available.
The Toe Clamp Kit Is a versatile kit that contains a wide range of clamping components of different lengths and sizes. Giving you an extensive range of options to clamp your parts, fixtures, or workholding securely to the mill table.
The Haas Toolholder Fixture provides a safe, easy, and secure way to securely tighten your pull studs and cutting tools into your toolholders. Featuring a lightweight cast iron body, with a compact design that mounts easily to a worktable or tool cart.
The Soft Steel and Aluminum Machinable Vise Jaws are easily machined to the shape of your part for custom workholding applications.
This Kit Contains:
  • Haas Workholding by Kurt 150mm Single-Station Fixed-Jaw Vise
  • Haas BT40Toolholder Fixture/Vise
  • Toe Clamp Kit for 16mm T-Slot Tables
  • Aluminum and Soft Steel Machinable Vise Jaws
Typ Zestawy różnych zacisków
Stożek BT40
Typ imadła Ręczne
Typ uchwytu imadła Nieruchoma szczęka
Liczba pozycji 1
[JW] Szerokość szczęki 6,0 cala \ 152,4 mm
[VO] Otwarcie imadła 9,0 cali \ 230,0 mm
CZY OSTATNIO CZYŚCIŁEŚ IMADŁO?
Twoje imadło może nadal pracować płynnie! Zobacz, jak czyścić i konserwować imadło.
Powiązane produkty
08-1903
