      • Frezarka do gniazd
      • Frezarki wspornikowe
      • Tokarka ręczna
      • Piły pionowe
      • Piła ukosowa
    • Obrabiarki kieszonkowe
      • Napędzane uchwyty tokarskie
      • Paleta narzędziowa
      • Torby na narzędzia
08-1087A
Paleta narzędziowa
Torby na narzędzia
Ostrzałki do narzędzi tnących
  2. Uchwyt roboczy frezarki
  3. Vise Kits
  4. 08-1087A
08-1087A
Zestaw frezarskich uchwytów roboczych, imadło ręczne 8", CT50
Nr części: 08-1087A
MILL WORKHOLDING KIT, 8" VISE, CT50
Cena: 2599.95 ( / artykuł)
2339.97
SETUPS MADE EASY
______________________________________________
BENEFITS:
This Mill Workholding Kit includes everything you need for basic workholding on a standard T-slot table. It contains a Single-Station Fixed-Jaw Vise, Toe Clamp Kit, and Toolholder Fixture/Vise.
The Single-Station Fixed-Jaw Vise is a flange-style vise that features a cast-in stationary jaw for less deflection and more stability during clamping. The proprietary AngLock® design ensures alignment of the moving jaw and reduces jaw lift for superior performance. The bolt-on jaws are easily changed or reversed, and machinable steel and aluminum soft jaws are available.
The Toe Clamp Kit Is a versatile kit that contains a wide range of clamping components of different lengths and sizes. Giving you an extensive range of options to clamp your parts, fixtures, or workholding securely to the mill table.
The Haas Toolholder Fixture provides a safe, easy, and secure way to securely tighten your pull studs and cutting tools into your toolholders. Featuring a lightweight cast iron body, with a compact design that mounts easily to a worktable or tool cart.
The Soft Steel and Aluminum Machinable Vise Jaws are easily machined to the shape of your part for custom workholding applications.
This Kit Contains:
  • Haas Workholding by Kurt 8" Single-Station Fixed-Jaw Vise
  • Haas CT50 (SK50/DIN) Toolholder Fixture/Vise
  • Toe Clamp Kit for 5/8" T-Slot Tables
  • Aluminum and Soft Steel Machinable Vise Jaws
  • Clamp Force Graph
  • KURT LIFETIME WARRANTY
CZY OSTATNIO CZYŚCIŁEŚ IMADŁO?
Twoje imadło może nadal pracować płynnie! Zobacz, jak czyścić i konserwować imadło.
Typ Zestawy różnych zacisków
Stożek CT50
Typ imadła Ręczne
Typ uchwytu imadła Nieruchoma szczęka
Liczba pozycji 1
[JW] Szerokość szczęki 8,0 cali \ 203,2 mm
[VO] Otwarcie imadła 10,6 cala \ 269,0 mm
08-1087A
