08-1087A
Inserti di brocciatura
  2. Serraggio dei pezzi fresatrice
  3. Vise Kits
  4. 08-1087A
08-1087A
Kit serraggio dei pezzi per fresatrice, morsa manuale 8", CT50
N. pezzo: 08-1087A
MILL WORKHOLDING KIT, 8" VISE, CT50
Prezzo: 2599.95 ( / unità)
2469.97
SETUPS MADE EASY
______________________________________________
BENEFITS:
This Mill Workholding Kit includes everything you need for basic workholding on a standard T-slot table. It contains a Single-Station Fixed-Jaw Vise, Toe Clamp Kit, and Toolholder Fixture/Vise.
The Single-Station Fixed-Jaw Vise is a flange-style vise that features a cast-in stationary jaw for less deflection and more stability during clamping. The proprietary AngLock® design ensures alignment of the moving jaw and reduces jaw lift for superior performance. The bolt-on jaws are easily changed or reversed, and machinable steel and aluminum soft jaws are available.
The Toe Clamp Kit Is a versatile kit that contains a wide range of clamping components of different lengths and sizes. Giving you an extensive range of options to clamp your parts, fixtures, or workholding securely to the mill table.
The Haas Toolholder Fixture provides a safe, easy, and secure way to securely tighten your pull studs and cutting tools into your toolholders. Featuring a lightweight cast iron body, with a compact design that mounts easily to a worktable or tool cart.
The Soft Steel and Aluminum Machinable Vise Jaws are easily machined to the shape of your part for custom workholding applications.
This Kit Contains:
  • Haas Workholding by Kurt 8" Single-Station Fixed-Jaw Vise
  • Haas CT50 (SK50/DIN) Toolholder Fixture/Vise
  • Toe Clamp Kit for 5/8" T-Slot Tables
  • Aluminum and Soft Steel Machinable Vise Jaws
  • Clamp Force Graph
  • KURT LIFETIME WARRANTY
HAI PULITO LA MORSA DI RECENTE?
Mantieni la morsa in funzione senza intoppi! Scopri come pulire e mantenere la morsa.
Tipo Kit assortito
Cono CT50
Tipo di morsa Manuale
Tipo di morsa Griffa fissa
Numero di stazioni 1
[JW] Ampiezza ganascia 8,0 pollici\203,2 mm
[VO] Apertura morsa 10,6 pollici \ 269,0 mm
08-1087A
