EC-1600ZT-5AX
  1. Horizontal Mills
  2. 50-Taper
  3. EC-1600ZT-5AX
EC-1600ZT-5AX
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
5-Axis CNC Horizontal Mill with 64" x 50" x 40" travels
The highly popular Haas EC Series HMCs offer large work cubes and a maximum part capacity of 10,000 lb, making them perfect solutions for your large-part machining requirements.
The EC-1600ZT-5AX has a 4th-axis rotary platter integrated into the T-slot table that provides ± 30 degrees of tilt. The 5th-axis consists of an HRT310 with an A-frame support mounted on a removable riser block that can support a part up to 55.875" long.
  • Extended Z-axis travel
  • 50-taper spindle with a 2-speed gearbox
  • Standard side-mount tool changer, 50+1 tools
  • Includes DWO/TCPC and Wireless Intuitive Probing System
  • 78" max part swing on integrated 4th axis
See Available Stock
Current Lead Time
  • 50 Taper
  • 5 Axis
  • 7.5k RPM
  • 50+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
50-Taper, 120+1 SMTC, 4+1 Pallet Pool
DOWNLOAD BROCHURE
HAAS JOURNAL
    Compare Machines
    BUILD & PRICE
    Contact Distributor
    • Build-&-Price
    • Specs
    • Machine Info
    Travels S.A.E METRIC
    X Axis 64.00 in 1626 mm
    Y Axis 50.00 in 1270 mm
    Z Axis 40.00 in 1016 mm
    Spindle S.A.E METRIC
    Max Rating 30.0 hp 22.4 kW
    Max Speed 7500 rpm 7500 rpm
    Max Torque 340.0 ft-lbf @ 700 rpm 460.0 Nm @ 700 rpm
    Drive System 2-Speed Gearbox 2-Speed Gearbox
    Taper CT or BT 50 CT or BT 50
    Table S.A.E METRIC
    Length 64.0 in 1626 mm
    Width 32.0 in 813 mm
    T-Slot Width 0.626 in to 0.630 in 15.90 mm to 16.00 mm
    T-Slot Center Distance 5.70 in 145 mm
    Number of Std T-Slots 5 5
    Max Weight on Table (evenly distributed) 10000 lb 4536 kg
    Integrated 4th Axis (B Axis) S.A.E METRIC
    Table 64 in x 32 in 1626 mm x 813 mm
    Platter Diameter 30.00 in 762 mm
    Travel ± 30 ° to 30- ° 30 ° to 30- °
    Max Part Swing 78.0 in 1981 mm
    Max Weight on Platter 10000 lb 4536.0 kg
    Max Rating 5.0 hp 3.7 kW
    Rotational Torque (continuous) 2000 ft-lbf 2712 Nm
    Backlash 30 arc-sec 30 arc-sec
    Gear Ratio 500:1 500:1
    Brake Torque 4000 ft-lbf 5423 Nm
    Min Resolution 0.001 ° 0.001 °
    Indexing Accuracy ± 30 arc-sec ± 30 arc-sec
    Repeatability 15 arc-sec 15 arc-sec
    Rapids on B 36 °/sec 36 °/sec
    Max Cutting B 36 °/sec 36 °/sec
    5th Axis (HRT310) A Axis S.A.E METRIC
    Travel 360 ° 360 °
    Platter Diameter 12.20 in 310 mm
    Number of Std T-Slots 6 EA @ 60 ° 6 EA @ 60 °
    Max Speed 75 °/sec 75 °/sec
    Torque (Continuous) 300 ft-lbf 407 Nm
    Brake Torque 500 ft-lbf 678 Nm
    Center Height 9.000 in 228.60 mm
    Max Weight on Platter (unsupported) 218 lb 98.9 kg
    Max Weight on Platter (w/support) 435 lb 197.3 kg
    General S.A.E METRIC
    Coolant Capacity 95 gal 360 L
    Tool Changer S.A.E METRIC
    Type SMTC SMTC
    Capacity 50+1 50+1
    Max Tool Diameter (full)** 4.0 in 102 mm
    Max Tool Diameter, Large (adjacent empty)** 10.0 in 254 mm
    Max Tool Length (from gage line) 20.00 in 508 mm
    Max Tool Weight 30.0 lb 13.6 kg
    Tool-to-Tool (avg) 8.00 s 8.00 s
    Chip-to-Chip (avg) 12.60 s 12.60 s
    Spindle Speed 7500 rpm 7500 rpm
    Spindle Power 30.0 hp 22.4 kW
    NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
    *Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
    Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
    **Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
    ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
    † Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
    AVAILABLE OPTIONS
    VIDEOS
    RELATED PRODUCTS
    Standard Features
    • 7500-rpm Spindle
    • 50+1 Side-Mount Tool Changer, 50-Taper
    • 5th-Axis Drive and Wiring
    • Built-In 4th-Axis Rotary Platter
    • Wireless Intuitive Probing System
    • Variable Flow Coolant
    • Chip Auger
    • Enclosure Exhaust System
    • 95-Gallon Coolant Tank
    • Chip Tray Filter Kit
    • Single-Stage Coolant Pump
    • Control Widescreen Monitor
    • Large Remote Jog Handle with Touchscreen Display
    • Ethernet Interface
    • CNC Control Cabinet Cooler
    • Power Surge Protection
    • Second Home Position
    • Advanced Tool Management
    • Media Display M-Code; M130
    • HaasDrop
    • Dynamic Work Offsets and Tool Center Point Control
    • Rigid Tapping
    • 28.5 ft Cable
    • ECO Mode
    • Stainless Steel Way Covers
    • Phone Charging Stand
    • A-Frame Support, 9"
    • 310 mm Servo Rotary Table
    Warranty
    • 1-Year Standard Warranty
    Available Options
    Automation Options
    • Installation Guide
    • Layout Drawing
    • Torque Chart
    • Operator’s Manual
    • EC Series Flyer
    VIDEOS
    Horizontal Mill: A Quick Overview
    Whether you need a horizontal machining center for high-volume production and unattended operation or really big work cubes and maximum weight capacity, Haas has an HMC that should fit the bill. This video gives an overview of our pallet changing mills, large-frame HMCs, and five-axis horizontal mills.
    EC-1600
    Haas Wireless Intuitive Probing System
    EC-1600ZT-5AX
    Display Pictures and Videos on Your Haas Control Using M130
    RELATED PRODUCTS
    DIFFERENT APPROACH
    Product Image
    VF-6/40TR
    Trunnion CNC Vertical Mill with 64" x 32" x 30" travels
    • 40 Taper
    • 5 Axis
    • 8.1k RPM
    • 30+1 Tool Capacity
        CNY ONLY
    Learn More Build & Price
    SMALLER WORK ENVELOPE
    Haas UMC-750
    UMC-750
    5-Axis CNC Vertical Mill with 30" x 20" x 20" travels
    • 40 Taper
    • 5 Axis
    • 8.1k RPM
        CNY ONLY
    All VF-2 columns are machined on EC-1600s
    HAAS MACHINES MAKING HAAS MACHINES!
    Build & Price
    Get Started
    Need More Information?
