HRT160-2
  1. Rotaries & Indexers
  2. Rotary Tables
  3. HRT160-2
HRT160-2
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
Dual-Platter 160 mm Rotary Table
For holding medium to large parts or fixtures, the HRT series of T-slotted rotary tables is the answer. These rugged, heavy-duty tables can be mounted vertically or horizontally for added versatility. Chucks and fixtures can easily be bolted to the table using the six precision T-slots, and large through-holes allow for bar feeding and special fixture-locating requirements.
The HRT160-2 has two rotary spindles to allow two workpieces to be loaded. This reduces the number of tool changes and the number of times the machine stops to load parts.
Note: Requires a Haas mill with 4th-axis drive and NGC software version 100.21.000.1130 or later for full 4th-axis operation. Stand-alone operation requires a Haas rotary control box shipped after November 10, 2021, with software version 26.38 or newer.
  • Add 4-axis capabilities to your machine
  • Increased productivity
  • Easy plug-and-play connection to Haas machines
  • Industry-leading performance and capabilities
  • 2 Spindles
  • 160 mm Platter Size
  • 110 ft-lb Max Torque
  • 80 °/sec Max Speed
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
Compare Machines
BUILD & PRICE
Contact Distributor
  • Build-&-Price
  • Specs
  • Machine Info
  • Rotary Fit chart
Platter S.A.E METRIC
Platter Diameter 6.30 in 160 mm
Max Weight on Platter (w/support) 70 lb 31.8 kg
Max Weight on Platter (unsupported) 35 lb 15.9 kg
Number of Std T-Slots 6 @ 60° 6 @ 60°
Spindle S.A.E METRIC
Number 2 2
Max Speed 80 °/sec 80 °/sec
Torque (Continuous) 110 ft-lbf 149 Nm
Runout Max 0.0005 in 0.013 mm
Center Height 6.750 in 171.45 mm
Backlash 30 arc-sec 30 arc-sec
Brake Torque @ 100 psi/6.9 bar 100 ft-lbf 136 Nm
Gear Ratio 63:1 63:1
Timing 2:1  2:1
Indexing S.A.E METRIC
Accuracy (±) ± 15.0 arc-sec ± 15.0 arc-sec
Repeatability 10 arc-sec 10 arc-sec
Resolution 0.001 ° 0.001 °
Worm Gear Dia 4.7 in 119 mm
Max Rotation/Step (with rotary control) 999.999 ° 999.999 °
General S.A.E METRIC
Power Requirement 115 VAC ±10% @ 15 A 115 VAC ±10% @ 15 A
Operating Temp (max ambient) 100 °F 38 °C
Air Pressure Max 150 psi 10.3 bar
Weight S.A.E METRIC
Table 198 lb 89.8 kg
Brushless Control 14.2 lb 6.4 kg
Export Crate 46.0 in x 24.0 in x 24.0 in 117 cm x 61 cm x 61 cm
Weight 285 lb 130.0 kg
AVAILABLE OPTIONS
VIDEOS
RELATED PRODUCTS
Standard Features
  • Direct Control by Mill CNC
Available Options
Automation Options
  • Layout Drawing
  • Operator’s Manual
  • Rotary Table Series Flyer
VIDEOS
CYLINDRICAL ENGRAVING USING G47/G107
Easily hand-program 4th-axis engraving on your Haas mill – without a CAM system. With G47 and G107, engraving on a cylindrical part couldn’t be easier.
UNWIND YOUR HAAS ROTARY QUICKLY
Today, Mark solves an issue every Haas Rotary user faces at some point: How do I get my rotary back to zero quickly?
How to Program a SAFE TOOL CHANGE POSITION
Mark shows how to command a safe tool change position to avoid crashing a tool into your fixture or rotary. It’s all done with a simple program, and referenced with an M-code.
Your new 5-axis compact rotary
If you make small parts and have multiple setups, this rotary is the perfect solution. Lightning fast and accurate, the TRT100 fits in nearly every Haas mill, and will help you cut cycle times and boost your shops efficiency.
RELATED PRODUCTS
Single-spindle alternative
Product Image
HRT160
160 mm Rotary Table
  • 1 Spindles
  • 150 ft-lb Max Torque
  • 130 °/sec Max Speed
    CNY ONLY
Learn More Build & Price
LARGER WORK ENVELOPE
Product Image
HRT210-2
Dual-Platter 210 mm Rotary Table
  • 2 Spindles
  • 210 mm Platter Size
  • 170 ft-lb Max Torque
  • 60 °/sec Max Speed
    CNY ONLY
Faster indexing
Product Image
HRT160SS
160 mm Super-Speed Rotary Table
  • 1 Spindles
  • 500 °/sec Max Speed
    CNY ONLY
HRT160-2 DM-1 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 DM-2 POSITIVE FIT
HRT160-2 DT-1 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 DT-2 POSITIVE FIT
HRT160-2 EC-1600 POSITIVE FIT
HRT160-2 EC-1600ZT POSITIVE FIT
HRT160-2 GR-510 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 GR-712 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 MINIMILL ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 MINIMILL2 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 SMINIMILL ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 SMINIMILL2 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 TM-1 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 TM-1P ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 TM-2 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 TM-2P ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 TM-3 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 TM-3P ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-1 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-10/40 POSITIVE FIT
HRT160-2 VF-10/50 POSITIVE FIT
HRT160-2 VF-11/40 POSITIVE FIT
HRT160-2 VF-11/50 POSITIVE FIT
HRT160-2 VF-12/40 POSITIVE FIT
HRT160-2 VF-12/50 POSITIVE FIT
HRT160-2 VF-1YT ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-2 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-2SS ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-2SSYT ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-2YT ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-3 POSITIVE FIT
HRT160-2 VF-3SS POSITIVE FIT
HRT160-2 VF-3SSYT POSITIVE FIT
HRT160-2 VF-3YT POSITIVE FIT
HRT160-2 VF-3YT/50 POSITIVE FIT
HRT160-2 VF-4 POSITIVE FIT
HRT160-2 VF-4SS POSITIVE FIT
HRT160-2 VF-5/40 POSITIVE FIT
HRT160-2 VF-5/40XT POSITIVE FIT
HRT160-2 VF-5/50 POSITIVE FIT
HRT160-2 VF-5/50XT POSITIVE FIT
HRT160-2 VF-5SS POSITIVE FIT
HRT160-2 VF-6/40 POSITIVE FIT
HRT160-2 VF-6/50 POSITIVE FIT
HRT160-2 VF-6SS POSITIVE FIT
HRT160-2 VF-7/40 POSITIVE FIT
HRT160-2 VF-7/50 POSITIVE FIT
HRT160-2 VF-8/40 POSITIVE FIT
HRT160-2 VF-8/50 POSITIVE FIT
HRT160-2 VF-9/40 POSITIVE FIT
HRT160-2 VF-9/50 POSITIVE FIT
HRT160-2 VM-2 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VM-3 POSITIVE FIT
HRT160-2 VM-6 POSITIVE FIT
HRT160-2 DT-1-I ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 DT-2-I POSITIVE FIT
HRT160-2 VF-2-I ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-2-V ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-2-EU ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-2-SE ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-4-I POSITIVE FIT
HRT160-2 VF-4-V POSITIVE FIT
HRT160-2 VF-4-EU POSITIVE FIT
HRT160-2 VF-4-SE POSITIVE FIT
HRT160-2 VF-4SS-V POSITIVE FIT
HRT160-2 VF-2SS-V ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-6SS-V POSITIVE FIT
HRT160-2 VF-5/40-I POSITIVE FIT
HRT160-2 VF-3-V POSITIVE FIT
HRT160-2 VF-3SS-V POSITIVE FIT
HRT160-2 MINIMILL-UK ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-1YT-EU ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-1SSYT-EU ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-2YT-EU ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-2SSYT-EU ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-14/40 POSITIVE FIT
HRT160-2 VF-14/50 POSITIVE FIT
HRT160-2 TM-0 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 TM-0P ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-2SSYT-UK ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-4SS-UK POSITIVE FIT
HRT160-2 VF-4SS-EU POSITIVE FIT
HRT160-2 VF-2YT-V ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-2SSYT-V ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-5SS-V POSITIVE FIT
HRT160-2 VF-5/40-V POSITIVE FIT
HRT160-2 MINIMILL-EDU ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-2YT-I ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-2SS-I ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-2SSYT-I ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VF-4SS-I POSITIVE FIT
HRT160-2 VF-5SS-I POSITIVE FIT
HRT160-2 DC-2/40 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 DM-3 POSITIVE FIT
HRT160-2 DT-3 POSITIVE FIT
HRT160-2 VF-7SS POSITIVE FIT
HRT160-2 VF-8SS POSITIVE FIT
HRT160-2 VM-8 POSITIVE FIT
HRT160-2 VP-5 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
HRT160-2 VM-9 POSITIVE FIT
HRT160-2 VF-9SS POSITIVE FIT
HRT160-2 VM-5 POSITIVE FIT
HRT160-2 VM-5/50 POSITIVE FIT
HRT160-2 VM-6/50 POSITIVE FIT
HRT160-2 VM-8/50 POSITIVE FIT
HRT160-2 VM-9/50 POSITIVE FIT
HRT160-2 VM-3/50 POSITIVE FIT
HRT160-2 VF-3YT-EU POSITIVE FIT
HRT160-2 VF-3SSYT-EU POSITIVE FIT
HRT160-2 VF-10SS POSITIVE FIT
HRT160-2 VF-11SS POSITIVE FIT
HRT160-2 VF-12SS POSITIVE FIT
HRT160-2 VF-14SS POSITIVE FIT
HRT160-2 VM-10 POSITIVE FIT
HRT160-2 VM-11 POSITIVE FIT
HRT160-2 VM-12 POSITIVE FIT
HRT160-2 VM-14 POSITIVE FIT
HRT160-2 VF-3SSYT/50 POSITIVE FIT
HRT160-2 VF-5SS/50 POSITIVE FIT
HRT160-2 VF-7SS/50 POSITIVE FIT
HRT160-2 VF-8SS/50 POSITIVE FIT
HRT160-2 VF-10SS/50 POSITIVE FIT
HRT160-2 VF-11SS/50 POSITIVE FIT
HRT160-2 VF-12SS/50 POSITIVE FIT
HRT160-2 VF-6SS/50 POSITIVE FIT
HRT160-2 VM-10/50 POSITIVE FIT
HRT160-2 VM-11/50 POSITIVE FIT
HRT160-2 VF-9SSZT POSITIVE FIT
HRT160-2 EC-1700ZT POSITIVE FIT
Build & Price
Get Started
Need More Information?
