      • Kniefrezen
      • Handbediende draaimachine
      • Verticale zaag
      • Verstekzaag
    • Kamerfrezen
      Kamerfrezen
      Kamerfrezen View All
      • Kamerfrezen
      • Flexibele slijpborstels
      • Gereedschapslade
      • Gereedschapszakken
      • Freesgereedschapslijpers
Coolant Level Float Sensor - Troubleshooting Guide
Service Home Koelmiddelvlottersensor - Handleiding voor probleemoplossing
- Ga naar oorzaak - Back to Top
16.2 Coolant Level Float Sensor - Troubleshooting Guide
Coolant Float Sensor - Troubleshooting Guide
Revision A - 04/2025
Coolant Level Float Sensor Inspection Report
Download and fill out the Coolant Float Sensor Inspection Report Checklist below before replacing any parts.
The image shows the following components of the Coolant Float Sensor:
  1. Float [1]
  2. Potentiometer [2]
  3. Bracket [3]
  4. Power Cord [4]
  5. Potentiometer Cover (not shown for clarity)
The coolant level sensor displays an incorrect coolant level. The coolant float is installed incorrectly.  See Check Float Installation section below.
The float is blocked and cannot move.  Clear all chips from float and coolant tank.
The factory settings 603 and 604 have the incorrect values.  Refer to Coolant Level Float Sensor - Installation for the correct parameter values.
The cable is damaged or unplugged.  Make sure that the cable is securely connected and is not damaged.
The sensor is damaged. Check all of the wires and clear chips blocking the float. Inspect for any leaks. If issue persists, follow the Malfunctioning Sensor section below.
Coolant level sensor displays 0% with no change when level sensor is moved up/down.  The coolant float is installed incorrectly.   See Check Float Installation section below.
The sensor is damaged or the float cannot move.  Check all of the wires and clear chips blocking the float. Inspect for any leaks. If issue persists, follow the Malfunctioning Sensor section below.
The I/O PCB isn't configured properly with the coolant level sensor.  Display analog input 13 while manually moving the coolant level float up/down. The input value should change from ~2500 to ~3150. If the input value remains the same, make sure that I/O configuration is correct. A-Input 13 should be mapped to P43.1. Refer to I/O Mapping section below.
Low coolant alerts appearing and disappearing frequently while machine is idle.
20022 and 20023 notification occurences in Alarm History.
Coolant level is close to 50%.  Fill coolant tank until coolant touches chip filter. Ensure that coolant level is above 70% before starting any operation that requires coolant. Clear any chips and debris from coolant filter, tank and machine. If issue persists, follow the Malfunctioning Sensor section below.
Low coolant alerts appearing and disappearing frequently while machine is cutting.
Coolant is cycling through the machine during operations.  Fill coolant tank until coolant touches chip filter. Ensure that coolant level is above 70% before starting any operation that requires coolant. Clear any chips and debris from coolant filter, tank, and machine. If issue persists, follow the Malfunctioning Sensor section below.
Check the orientation of the coolant tank lid. The cutout containing the coolant float [1] should be on the side of the coolant tank closest to the machine, as shown.
Ensure that the lid is sitting flat on top of the coolant tank.
Check that the dimples on the coolant float are properly seated in the dimples on the coolant tank. Check that the coolant float is sitting flat on top of the lid.
Re-fill coolant tank until coolant level touches the bottom of the chip filter [1].
In the first image, you can see the location of the coolant level sensor on the coolant tank.
If your coolant level sensor does not display the correct level on the screen, look in the coolant tank to make sure a chip build-up does not block the float from moving freely. Also, inspect the float for any leaks to make sure no coolant has wept in.
Corrective Action:
Make sure the coolant level sensor operates correctly:
  • Press [MEMORY]. The upper-right corner of the screen will show the coolant level.
  • Remove the coolant float sensor from the tank and manually move the float to max and min conditions.  The coolant level indicator on the screen should move at a slow pace. It takes approximately (1) minute to move from empty [2] to full [1] on the screen, but it starts to move immediately. Note the percentages that the coolant level indicator reports when the float is at min and max conditions.
  • If the coolant level sensor does not operate correctly, unplug the coolant level sensor from the machine.
Measure the voltage across the black [1] and white [2] wires on P43 on the I/O board when the float is up and down. The voltage should be approximately 3.8V when the float is up and 2.6V when it is down.
Measure the resistance at pins [2] and [4] on M12 connector when the float is up and down. The resistance should be approximately 371 Ohms when the float is up and 286 Ohms when it is down.
NOTE: Do not remove the coating around the wire, rather take the reading at the M12.
If another machine is present, test float on different machine. If the coolant level sensor continues to read incorrectly, and you have completed the troubleshooting instructions, replace the sensor.
 IMPORTANT: When returning the sensor, make sure to include an error report.
 IMPORTANT: When returning the sensor, please include the following information:
  • Machine state during malfunction (idle or cutting)
  • A video showing coolant level in the tank and on the pendant screen
  • Error Report
  • Resistance across black and white wires (see above)
I/O Mapping
The coolant level float sensor is controlled by analog input 13. The analog input uses an electronic counter to measure the input voltage signal. This input voltage signal is shown in the value section. For more information, refer to the Analog Sensors - Troubleshooting Guide.
As the coolant lower in the tank, the less input voltage there should be. As the coolant raises in the tank, the more input voltage there should be. When moving the coolant level float, the voltage value should change from ~2500 to ~3150.
The coolant level float sensor is connected to the I/O board at pin 43 shown in the connector section. Check the end of the M12 cable that is plugged into the I/O board to make sure the voltage across pin 3 and 4. If the 5VDC is not present, then troubleshoot the I/O PCB refer to the I/O PCB - Troubleshooting Guide.
Electrical Schematic
