Window Air Blast (WINDOW BLAST FEATURE)
Product Image
GET QUOTE
Window Air Blast
    CNY ONLY
  • Fitting mounts in the door
  • The machine’s air gun provides the compressed air
  • Tubing directs the air at the window to clear coolant and improve visibility
Splashing coolant and chips often make it difficult to see inside the machine while making parts. The Haas Window Blast feature is a simple yet effective solution that uses your machine’s airgun to quickly clear a section of the window – without stopping the machining process and opening the doors. This increases productivity by giving the operator a clear view of the work area during machining, simplifying part setup and production.
  • Option Info
DOCUMENTS
VIDEOS
AVAILABLE ON THESE MACHINES
SERVICE DOCUMENTS
VIDEOS
Window Air Blast
Love watching your parts get machined, but can’t see anything due to the splashing coolant on the window? With our window air blast, you can use the machine’s air gun to clear a section of the window, allowing you a clear view on your part being machined. No more stopping your machine and opening the doors just to take a peek inside.
Answer Man - Window Blast
A customer from Pleasanton, California, loves watching his Haas machine at work, and is curious if there's anything he can do about the coolant that sprays his machine's windows, obstructing his view. Watch as Steve and Bryan O'Fallon, resident Haas Answer Man, demonstrate the new Haas Window Blast feature, which uses the air gun on your Haas machine to clear coolant from the window.
  • Option Info
Need More Information?
