1.8k Spindle (1.8K-10HP-A2-6)
Product Image
GET QUOTE
1800-rpm Spindle, A2-6
    CNY ONLY
Optional spindle for the Toolroom Lathe Series
  • 1.8k speed
  • A2-6 nose
  • 10 hp power
  • Belt drive
  • Option Info
  • TORQUE CHART
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This 1800-rpm spindle features a larger spindle nose than the standard spindle, and provides a good combination of torque and rpm for a wide selection of machining operations.
  • A2-6 spindle nose with 3.5" (89 mm) bore
  • Shares the same design and bearings as the ST Series models
  • Excellent medium-duty spindle
  • Larger spindle bore for a wide range of applications
  • Accepts 8" (203 mm) or 10" (254 mm) manual chucks
Service Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
