12k Spindle, HSK-A63 (12K-HSK-A63)
Product Image
GET QUOTE
12,000-rpm Spindle, HSK-A63
    CNY ONLY
HSK spindle for UMC, VF, and VM series
  • 12k Speed
  • HSK-A 63 Taper
  • 30 hp Power
  • Inline Drive
  • Option Info
  • Torque Chart
OVERVIEW
SERVICE DOCUMENTS
VIDEOS
AVAILABLE ON THESE MACHINES
The Haas-designed 12,000-rpm HSK-A 63 spindle provides high rigidity and high stability for high-speed, extended-reach machining applications. The HSK (Hohl Shaft Kegel, or hollow-shank taper) tooling provides dual contact between the taper and the spindle face, providing a very rigid connection that offers excellent axial and radial accuracy, especially at high spindle speeds.
NOTE: Speeds higher than 10,000 rpm require toolholders balanced to a G2.5 rating at a speed greater than or equal to the operational rpm.
  • Dual-contact taper for high rigidity and high accuracy
  • More rigid toolholders for long-reach tools
  • Increased performance for 3D profiling
  • Increased performance when using small cutting tools
Service Documents
VIDEOS
HSK Taper Spindle
The HSK-A63 spindle is a great option for shops utilizing long-reach tools, or needing extra rigidity and accuracy at high speeds. The HSK tooling provides dual contact between the taper and spindle face, providing a very rigid connection.
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
