15k Spindle (15K-40T-15)
Product Image
GET QUOTE
15,000-rpm Spindle
    CNY ONLY
High-performance spindle for Drill/Mill Series
  • 15k Speed
  • 40 Taper
  • 15 hp Power
  • Inline Drive
  • Option Info
  • Torque Chart
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This Haas-built 40-taper inline direct-drive spindle provides 15,000 rpm for high-speed milling, and allows rigid tapping at speeds to 5000 rpm. The inline direct-drive spindle is coupled directly to the motor to provide excellent surface finishes and greater thermal stability.
NOTE: Speeds higher than 10,000 rpm require toolholders balanced to a G2.5 rating at a speed greater than or equal to the operational rpm.
  • 5000-rpm high-speed tapping
  • High acceleration/deceleration rates for reduced cycle times
  • Durable and reliable Haas-built spindle
  • 50% faster speeds and feeds than the standard spindle
  • Excellent performance on 3D surfacing applications
Service Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
