2.4k Spindle w/Rear Nose (2.4K-40HP-A2-8-RSN)
Product Image
GET QUOTE
2400-rpm Spindle w/Rear A2-8 Spindle Nose
    CNY ONLY
Dual-chuck spindle for the ST-40
  • 2.4k SPEED
  • A2-8 NOSE
  • 40 hp POWER
  • Gearbox DRIVE
  • Option Info
  • Torque CHart
  • Specs
OVERVIEW
DOCUMENTS
AVAILABLE ON THESE MACHINES
This 2-speed gearbox spindle is ideal for machining exotic metals or large-diameter parts that require a low surface speed. It provides good low-end torque without reducing the maximum speed of the spindle. Front and rear spindle noses provide dual-chuck capability.
  • Front and rear A2-8 spindle noses
  • Dual-chuck capability
  • 4.625" (117.5 mm) through bore
  • 2-speed gearbox
  • Increases low-end torque for demanding applications
ATTENTION! This option removes the chuck, draw tube, hydraulic union, and HPU from the machine, and modifies the left-hand enclosure sheet metal to allow rear chuck access.
Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
  • Overview
  • Torque Chart
  • Send Info
Service Documents
  • Chuck and Spindle Nose Comparison Chart
  • The best spindle choice for machining exotic metals
  • Improves metal removal rates
Note:
