3k Spindle (3K-10HP-A2-5)
Product Image
GET QUOTE
3000-rpm Spindle, A2-5
    CNY ONLY
Optional spindle for the Toolroom Lathe Series
  • 3k speed
  • A2-5 nose
  • 10 hp power
  • Belt drive
  • Option Info
  • TORQUE CHART
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This 3000-rpm spindle provides 67% more speed than the standard spindle, making it the best choice when turning small-diameter parts, or when part output is a priority.
  • A2-5 spindle nose with 2.3" (58 mm) spindle bore
  • Improves part finishes
  • Increases part output
  • Rigid and thermally stable
  • Accepts 8" (203 mm) manual chuck
Service Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
