4.5k Spindle (4.5K-10HP-A2-5)
Product Image
GET QUOTE
4500-rpm Spindle
    CNY ONLY
Standard spindle for the Pocket Lathe
  • 4500 speed
  • A2-5 nose
  • 10 hp power
  • Belt drive
  • Option Info
  • Torque Chart
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This 4500-rpm spindle has a 1.75" (44 mm) bar capacity, and provides plenty of speed and power for a wide range of applications.
  • High rpm for improved part finish
  • Allows high surface feeds for small-diameter parts
  • Yields shorter cycle times
Service Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
