6k HSK-A100 Spindle (6K-HSK-A100)
Product Image
GET QUOTE
6000-rpm Spindle, HSK-A100
    CNY ONLY
Standard spindle for HDC-3-5AX
  • 6k Speed
  • HSK-A100 Taper
  • 60 hp Power
  • Integral Motor Drive
  • Overview
  • Torque Chart
  • Send Info
Service Documents
This 6000-rpm spindle features an integral motor design that provides high power capability in a compact package. The HSK-A100 taper provides high rigidity and high stability for extended-reach machining applications. The HSK (Hohl Shaft Kegel, or hollow-shank taper) tooling provides dual contact between the taper and the spindle face, providing a very rigid connection that offers excellent axial and radial accuracy.
  • Dual-contact taper for high rigidity and high accuracy
  • More rigid toolholders for long-reach tools
  • High-power, integral motor design
  • Liquid cooled for thermal stability
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
