2.5k Gearbox Spindle (GBX35-SB)
Product Image
GET QUOTE
2500-rpm Gearbox Spindle
    CNY ONLY
Gear-driven spindle for the SB-35 Series
  • 2.5k speed
  • A2-8 nose
  • 40 hp power
  • Gearbox drive
  • Option Info
  • Torque Chart
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This optional spindle for the SB-35 Series box way lathes adds a 2-speed gearbox to boost torque to 1400 ft-lb, making it ideal for machining exotic metals or large-diameter parts that require a low surface speed.
  • The best spindle choice for machining exotic metals
  • Improves metal removal rates
  • Increases low-end torque for demanding applications
  • Chuck and Spindle Nose Comparison Chart
Service Documents
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
