Big-Bore Upgrade, Sub-Spindle, A2-5, 6.5" Chuck (SUB-SPDL-BB-6.5)
Product Image
GET QUOTE
Big-Bore Upgrade, Secondary-spindle, 6.5" Chuck
    CNY ONLY
Increases bore diameter and depth
  • A2-5 Spindle Nose
  • 6.5" Chuck Size
  • 1.81" Bore Diameter
  • 19" Bore Depth
  • Option Info
OVERVIEW
DOCUMENTS
VIDEOS
AVAILABLE ON THESE MACHINES
This big-bore upgrade for the A2-5 secondary-spindle on the DS-20Y and DS-25Y dual-spindle lathes increases the sub-spindle drawbar bore to 1.81" (46 mm), with a depth of 19" (483 mm), including the chuck throat.
  • 1.81" (46 mm) drawbar bore
  • 19" (483 mm) bore depth (including chuck throat)
  • Increases sub-spindle capabilities
  • Accommodates longer, larger diameter parts
NOTE: This option is field installable on all DS-20Y and DS-25Y models.
  • Layout Drawing
Service Documents
VIDEOS
Use G14 to Program Your Lathe Sub-Spindle
See just how easy it is to program your lathe sub-spindle. In this Tip of the Day, Mark walks you through how to use G14 and how to set up your tools when using a sub-spindle.
Sync Your Spindles with G199!
In this Tip of the Day, Mark shows how to synchronize the spindles on your Haas dual-spindle lathe. Learn how to hand off parts from the main to the sub-spindle, how to orient the chucks, and how to be sure the RPM on each spindle matches. With a great step-by-step explanation combined with some great animations and close-up shots of the spindles, you will walk away from this video an expert in spindle synchronization!
Need More Information?
