120+1 Side-Mount (SMTC-120-40T)
Product Image
GET QUOTE
120+1 Side-Mount Tool Changer
    CNY ONLY
High-production tool changer for UMCs and VMCs
  • Remote load station with automatic lockout
  • Bi-directional servo-driven positioning for fast tool staging
  • Mounts to the machine’s bridge and base for stability
  • Fast tool changes reduce non-cutting time
  • Tool Table allows complete control over the tool changer
  • Identify tools as LARGE to leave adjacent pockets empty
  • Identify tools as HEAVY to slow tool changer motion
  • 120+1 Tools
  • 40 Taper
  • Side-Mount Type
Estimated delivery for VF-3 and VF-4: June 2026.
Estimated delivery for UMC-1000: Q2 2026.
DOWNLOAD BROCHURE
HAAS JOURNAL
    • Option Info
    • Specs
    OVERVIEW
    DOCUMENTS
    VIDEOS
    AVAILABLE ON THESE MACHINES
    This Haas-designed 120+1 side-mount tool changer holds 120 tools, plus one in the spindle, providing plenty of locations for back-up tooling, or setting up tools for multiple jobs. It is the perfect choice for high-volume production, or for unattended, lights-out operation with a pallet pool, cobot, or robot.
    The tool changer features a double-arm gripper that swaps tools quickly to minimize non-cutting time, and a bi-directional servo-drive system allows direct positioning to any tool in the carousel. Faster positioning reduces cycle times during short machining operations, or when the carousel is not pre-staged for the next tool. A remote load station with automatic lockout function allows tool inspection, loading, and unloading while the machine is cutting, simplifying tool maintenance, and eliminating the need to load tools through the spindle.
    With adjacent pockets empty, the tool changer will accept oversize tooling, and there’s a built-in automatic recovery process, should a tool change be interrupted for any reason.
    Currently available for these models: UMC-500, UMC-750, VF-3, and VF-4.
        SERVICE DOCUMENTS
        VIDEOS
        Haas UMC-750 + 120-Pocket Tool Changer + Dual Rack Robot Pallet Loader
        Check out our super popular UMC-750 5-axis machining center outfitted with our new 120-pocket side-mount tool changer and dual-rack robotic pallet loader. This configuration is ready to run your parts lights out with plenty of tool and and fixture capacity for super extended run times.
        Haas 120 Pocket SMTC
        See the full Haas 120 Pocket SMTC system in motion.
        Tool Changer S.A.E METRIC
        Type SMTC SMTC
        Capacity 120+1 120+1
        Max Tool Diameter (full) 2.5 in 64 mm
        Max Tool Diameter, Large (adjacent empty) 5.0 in 127 mm
        Max Tool Length (from gage line) 12.00 in 305 mm
        Max Tool Weight 12.0 lb 5.4 kg
        Need More Information?
