30+1 Side-Mount, HSK (SMTC-30-HSK)
Product Image
GET QUOTE
30+1 Side-Mount Tool Changer, HSK
    CNY ONLY
High-production tool changer with super-fast carousel for HSK-taper mills
  • 30+1 Tools
  • HSK-A63 Taper
  • Side-Mount Type
  • Option Info
OVERVIEW
SERVICE DOCUMENTS
VIDEOS
AVAILABLE ON THESE MACHINES
This Haas-designed and -built 30+1 side-mount tool changer holds 30 tools, plus one in the spindle, to increase productivity and reduce setup times. A double-arm gripper swaps tools quickly to minimize non-cutting time. Locating the tool changer outside of the work envelope frees up additional workspace, keeps tools and tool pockets free of contamination, and adds greater flexibility when using large fixtures or rotary tables. With adjacent pockets empty, the tool changer will accept oversize tooling, and there’s a built-in automatic recovery process, should a tool change be interrupted for any reason.
This tool changer features a servo-driven carousel that allows direct positioning to any tool in the carousel. No more indexing one pocket at a time. Faster positioning reduces cycle times during short machining operations, or when the carousel is not pre-staged for the next tool.
  • HSK-A63 taper
  • Direct-positioning carousel for super-fast tool staging
  • Fast tool changes shorten cycle times on every tool change
  • Pocket Tool Table in the control allows complete control over the tool changer
  • Identify tools as LARGE to leave adjacent pockets empty
  • Identify tools as HEAVY to slow tool changer motion
SERVICE DOCUMENTS
VIDEOS
VIDEOS
Load and Unload Tools Easily Using Setting 420
In this Haas Tip of the Day, Mark introduces an “Enhanced” tool changer functionality, via Setting 420, that allows you to load and unload tools sequentially by tool number. Mark even explains how to perform this function on older controls using a macro statement.
MASTER THE HAAS SIDE-MOUNT TOOL CHANGER
In this Tip of the Day, Mark shows you how to use your Haas side-mount tool changer as efficiently as possible. Mark explains how to load large and heavy tools, and designate them in the control to avoid a collision.
M06 M-Code Timesavers
Product Specialist John Nelson explains how to ensure the M06 Tool Change and M05 Spindle Stop commands are functioning optimally, so they don’t slow down your programs unnecessarily.
Save Time by Pre-Staging Tools!
Save valuable time and keep your spindle turning by pre-staging your tools. With Mark’s simple programming tip, you can save seconds on every tool change; that adds up to some serious savings each week!
Need More Information?
