Anchoring Kit (ANCHORING KIT)
Product Image
GET QUOTE
Machine Anchoring Kit
    CNY ONLY
Anchor your machine for best performance
  • Option Info
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
Anchoring your Haas machine to a solid foundation helps ensure optimum performance, by providing a strong, rigid connection between the machine and the foundation. Our specially designed anchoring kit includes everything you need, and is much easier to install than competitors’ kits, requiring only a 5/8"-diameter hole for each anchor.
Machine Anchoring Kits include: anchoring straps, hardware, tube brush, 5/8" hammer drill bit, and machine anchoring template.
  • Increases the “apparent” mass of the machine
  • Improves dissipation of machine vibrations into the foundation
  • Improves overall stability and can reduce re-leveling requirements
  • Prevents axis acceleration from moving the machine
  • Keeps the machine aligned with accessory components (Bar Feeder, Pallet Pool , APL)
  • May be required for certain machine models (DT/DM, EC-1600, VS, and HDC), or accessories like the Haas Bar Feeder and APL
NOTE: Most Haas machines use the drop-in expansion style anchors listed above; however, the VS-1, VS-3, and HDC-3-5AX use larger epoxy style anchors. See the Service Documents for additional information and installation instructions.
SERVICE DOCUMENTS
Need More Information?
