QuikChange Cube System for HRTA6 (HQCCSA6-CUBE)
Product Image
GET QUOTE
    CNY ONLY
Kick your productivity into high gear
  • Overview
  • Send Info
Reduce cycle times and increase productivity by adding the Haas QuikChange Cube System to your Haas HRTA6 rotary table. Fixture cubes are loaded and released via pneumatic actuator, allowing the user to change cubes in less than 5 seconds. Mounting multiple parts to the cube increases productivity. Parts can be loaded/unloaded on one QuikChange Cube, while parts are being machined on another.
NOTE: Includes adapter plate, pneumatic actuator, hardware, and one QuikChange cube. Additional cubes must be purchased separately.
  • Machine multiple parts between tool changes
  • Load parts on one cube while machining parts on another
  • Pneumatic actuator allows quick changeovers
  • Easy installation; bolts to the back of the HRTA6
  • Includes adapter plate, pneumatic actuator, hardware, and 1 QuikChange Cube
Boost Your Output with Rotary Fixturing
Adding a Haas rotary to your VMC is the fastest way to boost throughput and increase accuracy. Adding a quick-change tooling plate or multi-sided fixture to your rotary allows you to get even more parts off the machine in less time. In this video, the Haas Answer Man walks you through our most popular rotary fixtures.
Need More Information?
