VOP-Advanced, ST-10Y-EU, ST-15Y-EU (VOP-ADV-10Y-15Y)
Advanced Package, ST-10Y-EU and ST-15Y-EU
    CNY ONLY
For ST-10Y-EU and ST-15Y-EU
  • Option Info
OVERVIEW
AVAILABLE ON THESE MACHINES
Our Advanced Package for ST-10Y-EU and ST-15Y-EU models includes everything in the Basic and Productivity Packages and adds a Parts Catcher System, ECO Mode Plus, and a Large Remote Jog Handle with Touchscreen Display.
Basic Package: Includes an auto door to reduce operator fatique, and open the door for future automation. The coolant sanitizer reduces bacteria and nasty smells. And our Coolant Maintenance Package includes everything you need to keep your coolant system filled with properly mixed coolant, your tank free of tramp oil, and your enclosure clear of mist and smoke generated during the machining process.
Productivity Package: The auxiliary coolant filter is a bag-style filtration system that keeps the coolant free of particulates down to 25 microns. The high-pressure coolant system provides 300 psi (21 bar) of coolant to the cutting tool for heavier cuts, higher feedrates, deep-hole drilling, and better surface finishes. The programmable chuck pressure option allows you to control the gripping force of the hydraulic chuck via the part program, or directly from the Haas control. The WiFi camera allows you to keep an eye on your machining processes remotely.
Advanced Package: Our two-stage automatic parts catcher moves completely out of the primary work envelope during machining, and quickly moves into place when commanded at the end of cycle. For parts with short cycle times, the arm can be left in the extended position, with only the tray rotating up to catch parts at the end of cycle. ECO Mode Plus is a hardware module connected to the machine’s incoming power that physically measures and tracks energy consumption. The extra-large remote jog handle with touchscreen display lets you get up-close to the machine’s work area for part setup, changeover, and inspection, while still having control of the machine.
Package Includes:
  • Auto Door
  • Coolant Maintenance Package
  • Coolant Sanitizer
  • Auxiliary Coolant Filter
  • High-Pressure Coolant
  • Programmable Chuck Pressure
  • WiFi Camera
  • Parts Catcher System
  • ECO Mode Plus
  • XL Remote Jog Handle
Need More Information?
