VOP-C EC-630 (VOP-C-EC-630)
70+1 Side-Mount Package – VOP C
    CNY ONLY
For the EC-630
  • Option Info
OVERVIEW
AVAILABLE ON THESE MACHINES
Our Value Option Package-C for the EC-630 includes includes everything in Packages A and B, and adds a 70+1 side-mount tool changer.
Package A: Includes Dynamic Work Offsets (DWO) and Tool Center Point Control (TCPC) to make setting up 4- and 5-axis jobs as easy as setting up a 3-axis machine. The high-speed machining option, which enables higher feedrates and more complex toolpaths without hesitation. The coolant refill system to keep your coolant tank filled with properly mixed coolant, and the coolant sanitizer to reduce bacteria and nasty smells. The WiFi camera allows you to keep an eye on your machining processes remotely. The Wireless Intuitive Probing System drastically reduces setup time.
Package B: The auxiliary coolant filter is a bag-style filtration system that keeps the coolant free of particulates down to 25 microns. The CDF conveyor has a built-in disc filtration system that prevents chips from entering the coolant tank, while the belt removes chips from the machine quickly, and discharges them at standard barrel height. Through-tool air blast and through-spindle coolant deliver high-pressure/high-flow air or coolant through the tool, directly to the cutting edge. You can easily switch between air and coolant through the tool, depending on the application.
Package C: The 70+1 side-mount tool changer provides plenty of capacity for multiple jobs and back-up tool groups.
Package Includes:
  • DWO/TCPC
  • High-Speed Machining
  • Coolant Refill System
  • Coolant Sanitizer
  • WiFi Camera
  • Wireless Intuitive Probing System
  • Auxiliary Coolant Filter
  • CDF Conveyor
  • Through-Spindle Air Blast
  • Through-Spindle Coolant, 300 psi
  • 70+1 Side-Mount Tool Changer
Need More Information?
