VOP-C, ST-10Y to ST-15Y (VOP-C-ST-10Y-15Y)
High-Pressure Coolant Package – VOP C
    CNY ONLY
For ST-10Y and ST-15Y
  • Option Info
OVERVIEW
AVAILABLE ON THESE MACHINES
Our Value Option Package-C for ST-10Y and ST-15Y models includes everything in Packages A and B, and adds an auxiliary coolant filter, high-pressure coolant, programmable chuck pressure, and WiFi Camara.
Package A: Includes an auto door to reduce operator fatique, and open the door for future automation; and a belt-type chip conveyor to efficiently remove chips from the enclosure.
Package B: The 6000-rpm live tooling upgrade increases the maximum speed of the driven tools from 4000 rpm to 6000 rpm, allowing higher surface feeds and reducing cycle times. The automatic tool presetter increases part accuracy and setup consistency, while reducing setup times by up to 50%. The system features easy-to-use automatic and manual modes of operation. The coolant mist condenser keeps the machine’s enclosure clear of mist and smoke generated during the machining process. The coolant refill system keeps your coolant tank filled with properly mixed coolant, and the coolant sanitizer reduces bacteria and nasty smells.
Package C: The auxiliary coolant filter is a bag-style filtration system that keeps the coolant free of particulates down to 25 microns. The high-pressure coolant system provides 300 psi (21 bar) of coolant coolant to the cutting too for heavier cuts, higher feedrates, deep-hole drilling, and better surface finishes. The programmable chuck pressure option allows you to control the gripping force of the hydraulic chuck via the part program, or directly from the Haas control. The WiFi camera allows you to keep an eye on your machining processes remotely.
Package Includes:
  • Auto Door
  • Belt-Type Chip Conveyor
  • 6000-rpm Live Tooling Upgrade
  • Automatic Tool Presetter
  • Mist Condenser
  • Coolant Refill System
  • Coolant Sanitizer
  • Auxiliary Coolant Filter
  • High-Pressure Coolant
  • Programmable Chuck Pressure
  • WiFi Camera
Need More Information?
