VOP-C UMC-400SS (VOP-C-UMC-400SS)
Through-Spindle Coolant Package – VOP C
    CNY ONLY
For the UMC-400SS
  • Option Info
OVERVIEW
AVAILABLE ON THESE MACHINES
Our Value Option Package-C for the UMC-400SS includes everything in Packages A and B, and adds the auxiliary coolant filter, through-tool air blast, and replaces TSC ready with 300 psi (21 bar) through-spindle coolant.
Package A: Includes broken tool detection, which uses a built-in camera to determine if a tool gets damaged during machining; and a programmable coolant nozzle to ensure coolant gets where it’s needed.
Package B: The coolant maintenance package keeps your coolant system filled and free of tramp oil, and the coolant sanitizer reduces bacteria and nasty smells. The WiFi camera allows you to keep an eye on your machining processes remotely.
Package C: The auxiliary coolant filter is a bag-style filtration system that keeps the coolant free of particulates down to 25 microns. Through-tool air blast and through-spindle coolant deliver high-pressure/high-flow air or coolant through the tool, directly to the cutting edge. You can easily switch between air and coolant through the tool, depending on the application.
Package Includes:
  • Broken Tool Detection
  • Programmable Coolant Nozzle
  • Coolant Maintenance Package
  • Coolant Sanitizer
  • WiFi Camera
  • Auxiliary Coolant Filter
  • Through-Tool Air Blast
  • Through-Spindle Coolant, 300 psi (21 bar)
Need More Information?
