VOP-D, DT and DM (VOP-D-VF-DT-DM)
Through-Spindle Coolant Package – VOP D
    CNY ONLY
For DT and DM series
  • Option Info
OVERVIEW
AVAILABLE ON THESE MACHINES
Our Value Option Package-D for DT and DM series models includes everything in Packages A, B, and C, and adds the auxiliary coolant filter, automatic air gun, minimum quantity lubrication system, through-tool air blast, and replaces TSC ready wit 300 psi (21 bar) through-spindle coolant.
Package A: Includes an auger-style chip conveyor to efficiently remove chips from the enclosure; and a programmable coolant nozzle to ensure coolant gets where it’s needed.
Package B: The high-speed machining option enables higher feedrates and more complex toolpaths without hesitation, and our Wireless Intuitive Probing System drastically reduces setup times.
Package C: The 4th-axis drive allows you to add a single-axis rotary table for machining multi-sided parts. The coolant maintenance package keeps your coolant system filled and free of tramp oil, and the coolant sanitizer reduces bacteria and nasty smells. The WiFi camera allows you to keep an eye on your machining processes remotely.
Package D: The auxiliary coolant filter is a bag-style filtration system that keeps the coolant free of particulates down to 25 microns. The automatic air gun supplies high-pressure/high-flow air directly to the cutting tool to clear chips safely and automatically during dry machining. The minimum quantity lubrication system delivers a steady blast of compressed air and a small quantity of cutting oil directly to the cutting tool to provide lubrication, reduce heat, and remove chips. Through-tool air blast and through-spindle coolant deliver high-pressure/high-flow air or coolant through the tool, directly to the cutting edge. You can easily switch between air and coolant through the tool, depending on the application.
Package Includes:
  • Chip Auger
  • Programmable Coolant Nozzle
  • High-Speed Machining
  • Wireless Intuitive Probing System
  • 4th-Axis Drive and Wiring
  • Coolant Maintenance Package
  • Coolant Sanitizer
  • WiFi Camera
  • Auxiliary Coolant Filter
  • Automatic Air Gun
  • Minimum Quantity Lubrication
  • Through-Tool Air Blast
  • Through-Spindle Coolant, 300 psi (21 bar)
Need More Information?
