VOP-D EC-1600 (VOP-D-EC-1600)
70+1 Side-Mount Package – VOP D
    CNY ONLY
For the EC-1600
  • Option Info
OVERVIEW
AVAILABLE ON THESE MACHINES
Our Value Option Package-D for the EC-1600 includes includes everything in Packages A, B, and C, and adds a 70+1 side-mount tool changer.
Package A: Includes Dynamic Work Offsets (DWO) and Tool Center Point Control (TCPC) to make setting up 4- and 5-axis jobs as easy as setting up a 3-axis machine. The high-speed machining option enables higher feedrates and more complex toolpaths without hesitation. The Wireless Intuitive Probing System drastically reduces setup times.
Package B: The integrated 4th-axis platter provides fully interpolated motion for contouring and positioning of large parts. The in-tank chip conveyor provides quick, high-volume chip removal for increased productivity. The coolant refill system keeps your coolant tank filled with properly mixed coolant, and the coolant sanitizer reduces bacteria and nasty smells. The WiFi camera allows you to keep an eye on your machining processes remotely.
Package C: The auxiliary coolant filter is a bag-style filtration system that keeps the coolant free of particulates down to 25 microns. Through-tool air blast and through-spindle coolant deliver high-pressure/high-flow air or coolant through the tool, directly to the cutting edge. You can easily switch between air and coolant through the tool, depending on the application.
Package D: The 70+1 side-mount tool changer provides plenty of capacity for multiple jobs and back-up tool groups.
Package Includes:
  • DWO/TCPC
  • High-Speed Machining
  • Wireless Intuitive Probing System
  • Integrated 4th-Axis Platter
  • In-Tank Chip Conveyor
  • Coolant Refill System
  • Coolant Sanitizer
  • WiFi Camera
  • Auxiliary Coolant Filter
  • Through-Tool Air Blast
  • Through-Spindle Coolant, 300 psi
  • 70+1 Side-Mount Tool Changer
Need More Information?
