VOP-E, Large VF (VOP-E-VF-LRG)
5th-Axis Package – VOP E
    CNY ONLY
For large VF models
  • Option Info
OVERVIEW
AVAILABLE ON THESE MACHINES
Our Value Option Package-E for large VF models includes everything in Packages A, B, C, and D, and adds a 5th-axis drive, DWO/TCPC, and second home position.
Package A: Includes an auto door to reduce operator fatique, and open the door for future automation; and high-intensity lighting to brighten your machine’s workspace.
Package B: The high-speed machining option enables higher feedrates and more complex toolpaths without hesitation, and our Wireless Intuitive Probing System drastically reduces setup times.
Package C: The 4th-axis drive allows you to add a single-axis rotary table for machining multi-sided parts. The coolant maintenance package keeps your coolant system filled and free of tramp oil, and the coolant sanitizer reduces bacteria and nasty smells. The WiFi camera allows you to keep an eye on your machining processes remotely.
Package D: The auxiliary coolant filter is a bag-style filtration system that keeps the coolant free of particulates down to 25 microns. The automatic air gun supplies high-pressure/high-flow air directly to the cutting tool to clear chips safely and automatically during dry machining. The minimum quantity lubrication system delivers a steady blast of compressed air and a small quantity of cutting oil directly to the cutting tool to provide lubrication, reduce heat, and remove chips. Through-tool air blast and through-spindle coolant deliver high-pressure/high-flow air or coolant through the tool, directly to the cutting edge. You can easily switch between air and coolant through the tool, depending on the application.
Package E: The 5th-axis drive allows you to add a dual-axis rotary table for 3+2 positioning and full 5-axis machining of complex parts. Dynamic Work Offsets (DWO) and Tool Center Point Control (TCPC) are features in the Haas control that make setting up 4- and 5-axis jobs as easy as setting up a 3-axis machine. And the second home position option allows the operator to quickly send the machine’s axes to user-defined Home position that’s different than the machine’s standard Home position, for tool loading, tool inspection, or part loading.
Package Includes:
  • Auto Door
  • High-Intensity Lighting
  • High-Speed Machining
  • Wireless Intuitive Probing System
  • 4th-Axis Drive and Wiring
  • Coolant Maintenance Package
  • Coolant Sanitizer
  • WiFi Camera
  • Auxiliary Coolant Filter
  • Automatic Air Gun
  • Minimum Quantity Lubrication
  • Through-Tool Air Blast
  • Through-Spindle Coolant, 300 psi (21 bar)
  • 5th-Axis Drive and Wiring
  • DWO/TCPC
  • Second Home Position
Need More Information?
