VOP-F, VF-4SS (VOP-F-VF-SS-MD)
Automation Package – VOP F
    CNY ONLY
For the VF-4SS
  • Option Info
OVERVIEW
AVAILABLE ON THESE MACHINES
Our Value Option Package-F for the VF-4SSY includes most everything in Packages A, B, C, D, and E, and adds a 120+1 side-mount tool changer, 95-gallon coolant tank, broken tool detection, quad-auger conveyor system, and 5+1 pallet pool.
Package A: Includes high-intensity lighting to brighten your machine’s workspace; and a programmable coolant nozzle to ensure coolant gets where it’s needed.
Package B: The high-speed machining option enables higher feedrates and more complex toolpaths without hesitation, and our Wireless Intuitive Probing System drastically reduces setup times.
Package C: The auto door reduces operator fatique, and opens the door for future automation. The coolant maintenance package keeps your coolant system filled and free of tramp oil, and the coolant sanitizer reduces bacteria and nasty smells. The WiFi camera allows you to keep an eye on your machining processes remotely.
Package D: The auxiliary coolant filter is a bag-style filtration system that keeps the coolant free of particulates down to 25 microns. The automatic air gun supplies high-pressure/high-flow air directly to the cutting tool to clear chips safely and automatically during dry machining. The minimum quantity lubrication system delivers a steady blast of compressed air and a small quantity of cutting oil directly to the cutting tool to provide lubrication, reduce heat, and remove chips. Through-tool air blast and through-spindle coolant deliver high-pressure/high-flow air or coolant through the tool, directly to the cutting edge. You can easily switch between air and coolant through the tool, depending on the application.
Package E: The second home position option allows the operator to quickly send the machine’s axes to user-defined Home position that’s different than the machine’s standard Home position, for tool loading, tool inspection, or part loading. And the extra-large remote jog handle with touchscreen display lets you get up-close to the machine’s work area for part setup, changeover, and inspection, while still having control of the machine.
Package F: The 120+1 side-mount tool changer provides plenty of capacity for multiple jobs, back-up tool groups, and unattended machining. Broken tool detection visually compares tools before and after a tool change, and if a broken tool is detected, the machine prevents the tool from being swapped into the spindle. The 95-gallon coolant tank ensures there’s plenty of coolant to prevent pump starvation during continuous operation. The 5+1 pallet pool allows lights-out unattended operation, and is perfect for high-volume production runs, or high-mix/low-volume machining. The quad-auger chip conveyor system keeps the enclosure free of chips during long production runs and unattended operation.
Package Includes:
  • High-Intensity Lighting
  • Programmable Coolant Nozzle
  • High-Speed Machining
  • Wireless Intuitive Probing System
  • Auto Door
  • Coolant Maintenance Package
  • Coolant Sanitizer
  • WiFi Camera
  • Auxiliary Coolant Filter
  • Automatic Air Gun
  • Minimum Quantity Lubrication
  • 95-Gallon Coolant Tank
  • Through-Tool Air Blast
  • Through-Spindle Coolant, 300 psi (21 bar)
  • Second Home Position
  • XL Remote Jog Handle w/Touchscreen
  • 120+1 Side-Mount Tool Changer
  • Broken Tool Detection
  • 5+1 Pallet Pool
  • Quad-Auger Conveyor System
Need More Information?
