VOP-3+1 Pallet Pool, VF-2YT-EU (VOP-PP3-VF)
3+1 Pallet Pool Package, VF-2YT-EU
    CNY ONLY
For the VF-2YT-EU
  • Option Info
OVERVIEW
AVAILABLE ON THESE MACHINES
Our Value Option Package-3+1 Pallet Pool for the VF-2YT-EU includes the coolant maintenance package, wireless intuitive probing system, high-speed machining, programmable coolant nozzle, ECO Mode Plus, coolant sanitizer, WiFi camera, auxiliary coolant filter, automatic air gun, minimum quantity lubrication, through-tool air blast, through-spindle coolant, second home, XL remote jog handle, 70+1 side-mount tool changer, dual-auger conveyor, and 3+1 pallet pool.
3+1 Pallet Pool Package: The coolant maintenance package includes everything you need to keep your coolant system filled with properly mixed coolant, your tank free of tramp oil, and your enclosure clear of mist and smoke generated during the machining process. The wireless intuitive probing system drastically reduces setup times. The high-speed machining option enables higher feedrates and more complex toolpaths without hesitation. The programmable coolant nozzle ensures coolant gets where it’s needed. ECO Mode Plus is a hardware module that physically measures and tracks energy consumption.
The coolant sanitizer reduces bacteria and nasty smells. The WiFi camera allows you to keep an eye on your machining processes remotely. The auxiliary coolant filter is a bag-style filtration system that keeps the coolant free of particulates down to 25 microns. The automatic air gun supplies high-pressure/high-flow air directly to the cutting tool to clear chips safely and automatically during dry machining. The minimum quantity lubrication system delivers a steady blast of compressed air and a small quantity of cutting oil directly to the cutting tool to provide lubrication, reduce heat, and remove chips. Through-tool air blast delivers high-pressure/high-flow air through the tool, directly to the cutting edge. Through-spindle coolant provides 300 psi (21 bar) of coolant through the cutting tool for heavier cuts, higher feedrates, deep-hole drilling, and better surface finishes. You can easily switch between air and coolant through the tool, depending on the application.
 The second home position option allows the operator to quickly send the machine’s axes to user-defined Home position that’s different than the machine’s standard Home position, for tool loading, tool inspection, or part loading. And the extra-large remote jog handle with touchscreen display lets you get up-close to the machine’s work area for part setup, changeover, and inspection, while still having control of the machine.
The 70+1 side-mount tool changer provides plenty of capacity for multiple jobs, back-up tool groups, and unattended machining. The dual-auger chip conveyor system keeps the enclosure free of chips during long production runs and unattended operation. The 3+1 pallet pool allows lights-out unattended operation, and is perfect for high-volume production runs, or high-mix/low-volume machining.
Package Includes:
  • ECO Mode Plus
  • Programmable Coolant Nozzle
  • High-Speed Machining
  • Wireless Intuitive Probing System
  • Coolant Sanitizer
  • Through-Tool Air Blast
  • WiFi Camera
  • Auxiliary Coolant Filter
  • Automatic Air Gun
  • Minimum Quantity Lubrication
  • Through-Spindle Coolant, 300 psi (21 bar)
  • Second Home Position
  • XL Remote Jog Handle w/Touchscreen
  • 70+1 Side-Mount Tool Changer
  • Dual-Auger Conveyor System
  • 3+1 Pallet Pool
Need More Information?
