VOP-Productivity, ST-20Y-EU, ST-30Y-EU (VOP-PROD-20Y-30Y)
Productivity Package, ST-20Y-EU and ST-30Y-EU
    CNY ONLY
For ST-20Y-EU and ST-30Y-EU
  • Option Info
OVERVIEW
AVAILABLE ON THESE MACHINES
Our Productivity Package for ST-20Y-EU and ST-30Y-EU models includes everything in the Basic package, and adds an auxiliary coolant filter, high-pressure coolant, programmable chuck pressure, and WiFi camera.
Basic Package: Includes an auto door to reduce operator fatique, and open the door for future automation. High-Intensity Lighting includes external LED lights that turn on/off automatically with the machine doors, or manually via switch. The coolant sanitizer reduces bacteria and nasty smells. And our Coolant Maintenance Package includes everything you need to keep your coolant system filled with properly mixed coolant, your tank free of tramp oil, and your enclosure clear of mist and smoke generated during the machining process.
Productivity Package: The auxiliary coolant filter is a bag-style filtration system that keeps the coolant free of particulates down to 25 microns. The high-pressure coolant system provides 300 psi (21 bar) of coolant to the cutting tool for heavier cuts, higher feedrates, deep-hole drilling, and better surface finishes. The programmable chuck pressure option allows you to control the gripping force of the hydraulic chuck via the part program, or directly from the Haas control. The WiFi camera allows you to keep an eye on your machining processes remotely.
Package Includes:
  • Auto Door
  • High-Intensity Lighting;
  • Coolant Maintenance Package
  • Coolant Sanitizer
  • High-Pressure Coolant
  • Auxiliary Coolant Filter
  • Programmable Chuck Pressure
  • WiFi Camera
Need More Information?
