VOP-Sub-Spindle, ST-10LY-EU, ST-15LY-EU (VOP-SUB-10LY-15LY)
Sub-Spindle Package, ST-10LY-EU and ST-15LY-EU
    CNY ONLY
For ST-10LY-EU and ST-15LY-EU
  • Option Info
OVERVIEW
AVAILABLE ON THESE MACHINES
Our Sub-Spindle Package for ST-10LY-EU and ST-15LY-EU models includes everything in the Basic and Advanced Packages, and adds CNC control cabinet cooler, main spindle air blast, sub-spindle air blast, and an A2-5 sub-spindle.
Basic Package: Includes an auto door to reduce operator fatique, and open the door for future automation. The coolant sanitizer reduces bacteria and nasty smells. And our Coolant Maintenance Package includes everything you need to keep your coolant system filled with properly mixed coolant, your tank free of tramp oil, and your enclosure clear of mist and smoke generated during the machining process.
Advanced Package: The auxiliary coolant filter is a bag-style filtration system that keeps the coolant free of particulates down to 25 microns. The high-pressure coolant system provides 300 psi (21 bar) of coolant to the cutting tool for heavier cuts, higher feedrates, deep-hole drilling, and better surface finishes. The programmable chuck pressure option allows you to control the gripping force of the hydraulic chuck via the part program, or directly from the Haas control. The WiFi camera allows you to keep an eye on your machining processes remotely. ECO Mode Plus is a hardware module connected to the machine's incoming power that physically measures and tracks energy consumption. The extra-large remote jog handle with touchscreen display lets you get up-close to the machine’s work area for part setup, changeover, and inspection, while still having control of the machine.
Sub-Spindle Package: The CNC control cabinet cooler reduces the internal temperature of the control cabinet to boost reliability and increase component life. The main spindle air blast and sub-spindle air blast keep your workpiece and/or workholding clear of chips, without having to open the operator door. Activated by M-code, the air blast can be programmed to activate while the spindle is turning, at the end of cycle, or before a part pass-off to the sub-spindle. Our A2-5 sub-spindle will not only make you more productive, but also provide new options for finishing the 2nd-op side of your parts. The sub-spindle will fully synchronize with the main spindle for effortless in-cycle part handoff.
Package Includes:
  • Auto Door
  • Coolant Maintenance Package
  • Coolant Sanitizer
  • ECO Mode Plus
  • CNC Control Cabinet Cooler
  • Auxiliary Coolant Filter
  • High-Pressure Coolant
  • Programmable Chuck Pressure
  • WiFi Camera
  • XL Remote Jog Handle
  • Main Spindle Air Blast
  • Sub-Spindle Air Blast
  • A2-5 Sub-Spindle
Need More Information?
