G-code, M-code, and Setting
Service Home G00 Rapid Motion Positioning (Group 01)
*B - B-axis motion command
*C - C-Axis motion command
*U - X-axis incremental motion command
*W - Z-axis incremental motion command
*X - X-axis absolute motion command
*Y - Y-axis absolute motion command
*Z - Z-axis absolute motion command
* E - Optional code to specify the rapid rate of the block as a percent.
* indicates optionalThis G code is used to move the machine's axes at the maximum speed. It is primarily used to quickly position the machine to a given point before each feed (cutting) command. This G code is modal, so a block with G00 causes all following blocks to be rapid motions until another cutting move is specified.
NOTE: Generally, rapid motion will not be in a straight line. Each axis specified is moved at the same speed, but all axes will not necessarily complete their motions at the same time. The machine will wait until all motions are complete before starting the next command.
